Door Leak
Door Leak
Guess I am the only one with this problem???
Our 2014 hardtop JK leaks around the molding at the top and most forward point of the driver's door. The molding looks exactly the same on both sides, but only the driver's side leaks. [original molding] If the wind is blowing the water comes right in.
The curious thing is that it looks like the molding has been trimmed.
No, you are not. My hard top has been leaking since new. Replaced the moldings under warranty, made the situation worse. Used all my Aerospace Repair & Overhaul skills(tried trimming @ caulking) to no avail. Gave up and pulled the drain plugs. Don't crank the wings to tight, you will get leaking from the center speakers, and over the radio console. It gets really bad here in the winter, freeze and thaw. I park facing uphill to discourage water getting in.
Sounds like your leak is center-line from the removable panels, while mine is from the forward end of the driver door. The area of the molding that looks like it has been trimmed, but has not. See picture.
Not sure if this document will help you or if I have the permissions right... It's the water leaks repair manual that Jeep uses.
https://drive.google.com/drive/folde...2VXNEpqN3ZaNEk
dmalpas (09-20-2018)
[QUOTE=jedg;4328901]Not sure if this document will help you or if I have the permissions right... It's the water leaks repair manual that Jeep uses.
/QUOTE]
Well, isn't that just handy. Much appreciated.
/QUOTE]
[QUOTE=dmalpas;4328905]Were you able to get to it? Just want to know so that I can be sure I have the permissions correct.
I've had exact the same problem with my 14 JK. It's still there but when I use silicon grease on the rubber parts, on the doors and roof, it will go away for a time until it dries out again.
tango romeo papa circa 67 (09-24-2023)
