AEV Tire carrier third brake light
Old 10-07-2016, 06:21 AM
ShawnNoble's Avatar
Default AEV Tire carrier third brake light
I am installing an AEV tire carrier and was wondering for those using it what third brake light set ups are in use. I like the look of the stock light but dont think I can use it with this carrier. Anyone have info on one that looks like the stock light that works?
Thanks,
Old 10-07-2016, 07:16 AM
Canvas's Avatar
a quick Bing search and I found this.
Not sure if this is your carrier.
Old 10-07-2016, 07:42 AM
GeauxJeep's Avatar
This is my temp solution until i get the fuel carrier. it's basically a red led marker light from an auto parts store. i just have it zip tied for now. Made it through state inspection with no questions.
Old 10-07-2016, 12:06 PM
ShawnNoble's Avatar
I bought the fuel caddy with mine. Is there a light solution using the fuel caddy?
Old 10-07-2016, 01:01 PM
Canvas's Avatar
You will have to fabricate a bracket.
Old 10-09-2016, 11:12 PM
jsukey's Avatar
I liked the rear light as well, but of course you lose it with the AEV bumper and tire carrier. After searching around online, I ended up going with these since they looked clean. They are plenty bright, and look great!
Delta Tech Delta Waterproof Lug Nut Light for Aftermarket Swing Spare Tire | Quadratec
Old 10-10-2016, 10:24 AM
ShawnNoble's Avatar
I like the look of that. How hard was it to wire in to the factory wiring?
Old 10-10-2016, 01:36 PM
jsukey's Avatar
It's super easy to do since the wiring is already there. It piggybacks off of the original brake light. The whole install took less than 45 minutes.
Old 10-11-2016, 04:55 PM
Armergedon007's Avatar
I made a bracket using some angled aluminum from home depot. I cut the light from the stock bracket and bolted it to the new bracket. I had to add a little extra wire to the stock light harness. I will take a picture when I get a chance.
Old 10-11-2016, 05:18 PM
karls10jk's Avatar
I bought the Delta kit as well and wish I hadn't. You can buy the same LED's from an American company on eBay for $12 shipped. That leaves you $26 for wiring loom and quick disconnect pieces.
To your question on the aev w/ fuel caddy- it looks like all of their bumpers have that post sticking above the tire. You could do the LED lug nuts and just put them into a piece of 4*4" aluminum bent in half and bolted to the top. I've got a similar solution working on my tire carrier because removing the lug nut lights to rotate tires gets old after you do a couple rotations.
You could do something very similar to this on top of your post.
Quick Reply: AEV Tire carrier third brake light
