TATAs ProLink from Factor 55
Old 04-28-2013, 11:48 AM
Topless for TATAs's Avatar
Default TATAs ProLink from Factor 55
FACTOR 55 TATAs ProLink
SAFER STRONGER SMARTER
Factor 55 announces the release of their patent pending ProLink shackle mount for winches. The ProLink allows winch owners to replace the conventional winch hook with a safer and stronger shackle/D-Ring. Winch hooks can cut and fray recovery straps and often allow strap loops to escape during typical loose/tight cycles of a winching recovery. Screw pin shackles do not allow strap loops to escape due to the secure screw pin attachment. The ProLink does not require splicing and is compatible with either steel cables or synthetic ropes. The cable eye is retained in the ProLink by an oversized 5/8 inch titanium double shear pin and internal snap ring. It is easily installed in minutes. The EPDM Rubber Guard protects alloy fairleads and is securely attached to the ProLink with 8 barbed tips. The ProLink stows neatly against either roller or Hawse type fairleads and is designed to be used with common standard ¾ inch shackles. MADE IN THE USA, the ProLink is constructed of 6000 series billet aluminum and anodized/powder coated in 5 different colors. The ProLink has a max load rating of 16,000 pounds and an ultimate failure of 40,000 pounds.
FEATURES
• Engineered, Tested, and Made in USA – USA Patent Pending
• Billet construction – precision machined from 6061-T6 Kaiser Aluminum round bar
• 16,000 pound max load rating
• 40,000 pound ultimate failure
• Fits all steel cables and synthetic ropes up to 3/8” in diameter
• Fits loops equipped with standard or tube thimbles to 3/8 inch diameters
• 1.2 inch shackle tab thickness virtually eliminates “shackle rattle”
• Massive 5/8 inch diameter stainless steel double shear pin - 6Al-4V Titanium upgradeable
• Optional EPDM “Rubber Guard” protects alloy Hawse fairleads – rubber barb attachment
• Can be installed and removed in minutes – simple snap ring removal
• Cinches neatly against all types of fairleads – Hawse or Roller
• Shackle mounting hole fits all ¾” screw pin shackles
Installation: Simply remove your existing hook from your cable or rope loop, and install the ProLink using snap ring pliers. Be sure to completely seat the snap ring.
SAFETY FIRST! Always follow safe winching guidelines recommended by your winch manufacturer.
Click to order yours today! $50 of the purchase price will be donated to Topless for TATAs!
Old 05-22-2013, 04:55 PM
Link to go shopping!
Topless for TATAs Swag Store
Quick Reply: TATAs ProLink from Factor 55
