Sponsored by:
Sponsored by:
Drag link set up question?
Old 08-09-2017, 04:01 PM
wrnglrguy's Avatar
Default Drag link set up question?
I installed a Synergy drag link flip. I know that because of the weight, the drag link tends to droop at the bend near the knuckle side. The drag link droops down until one or both end joints are maxed out.
So my question is, which end....pitman arm, knuckle, or both, should be maxed out in one direction? I do not want to lose any flexing ability or put the steering in a bind when wheeling. I especially do not want to damage anything.
Currently, the pitman arm side is maxed in one direction while the knuckle side is fairly level. Thoughts....opinion?
Old 08-09-2017, 05:47 PM
Monte417's Avatar
Originally Posted by wrnglrguy
I installed a Synergy drag link flip. I know that because of the weight, the drag link tends to droop at the bend near the knuckle side. The drag link droops down until one or both end joints are maxed out. So my question is, which end....pitman arm, knuckle, or both, should be maxed out in one direction? I do not want to lose any flexing ability or put the steering in a bind when wheeling. I especially do not want to damage anything. Currently, the pitman arm side is maxed in one direction while the knuckle side is fairly level. Thoughts....opinion?
That's the way i have mine. It's been like that for 3+ years and never had a problem
Quick Reply: Drag link set up question?
