Sponsored by:
Sponsored by:
Optimal tire pressure with 35" tires?
Old 05-11-2011, 09:21 PM
Bauker's Avatar
Default Optimal tire pressure with 35" tires?
They installed my wheels with 48psi and it's a little rough on the bumps. Kinda jolts the steering as well. I know this can be solved by getting the tire pressure correct. Hoping someone had the cure!
Old 05-11-2011, 09:24 PM
peanut's Avatar
I have bfg km2's and use 29 psi on road & 18 to 12 off road 2 door soft top
Old 05-11-2011, 10:10 PM
Bauker's Avatar
Are they 35s? Just want to double check. Thanks!
Old 05-11-2011, 10:32 PM
Sprocket's Avatar
48psi seems really high... Find out what the tire brand recommends and go with that. Just a slight variation from the recommended air pressure can make significant changes in performance, safety, and tire longevity..
Old 05-11-2011, 10:51 PM
SiiiViiiT's Avatar
Don't get torn on them setting it at 48 psi because they probably just left it there after seating the bead and never bothered bringing it down to the proper psi. When I got my tires mounted they had one set at 55 psi and the others around 48 psi. Anyways, I run my 35" KM2's at 30 psi and I have a 4dr hardtop.
Old 05-12-2011, 02:40 AM
firejeep508's Avatar
If you want to be precise (anal) on the proper pressure to run, here's the trick:
Get some chalk and draw a line across the tread. Drive a few hundred yards. Check to see where the chalk wears off. If the chalk wears off more in the center than on the edges, you need to lower pressure. If it wears off more on the edges, then you need to increase pressure. Repeat until the line wears off evenly across the tread. Once the wear is even, make note of the pressure and roll with it.
Doing this ensures even tread wear and will help extend the life of the tires. I do believe you should at least run down to about 33-35 before starting this process. 48 is way high.
HTH!
Montego (01-07-2023)
Old 05-12-2011, 06:34 AM
Bauker's Avatar
This is awesome guys, thanks for the info. I think 13.5 PSI (at the min) is going to make a HUGE difference in the ride quality. Now maybe I can stop bracing for impact like Captain James T. Kirk when I see a bump coming! Ill try the chalk thing too just to be certain.
Old 05-12-2011, 07:21 AM
saravonshep's Avatar
I have Nitto Mud Grapplers 35 12.5 17 and i run them at around 27 or so on the road. Off road ill air down to between 8-15 PSI depending on what im doing.
Old 05-12-2011, 07:47 AM
Bauker's Avatar
I just aired down to 35psi and it made a world of a difference. It's almost back to it's stock driving mannerisms. I'm sure going to 27 would be like floating on a cloud.
Old 05-12-2011, 07:50 AM
Work in Progress - JK's Avatar
BFG KM2's 35's over 15" - run 35 psi on the road and 12 to 14 on the trail.
Name:	My JK lifted 007.jpg
Quick Reply: Optimal tire pressure with 35" tires?
