Jeepbronco1 SUT build (my mini truck build)
#301
Thank you ! It's RK long arm lift and then I just moved the brackets further back . So you can achieve whatever stretch you need . Hope it helps !
#303
#304
You can special order from RK your control arms . You can get them with less bend as well as longer . If my link were straigher I could have less rub . Also you will need to notch the frame unless you go quiet a bit wider , You will have rubbing issues there. All in all it rubs a little here and there but it isn't enough for me to worry about
#305
I moved the front forward a few inches as well , but I do rub on full lock . A ford d60 has 8" of ram movement and stock jeep has 6" if I recall correctly . I had to restrict my ram to 8" for both my steering box and other wise id rub big time .
#306
So mainly rubbing on the control arms? I thought the bend was inboard of the jeep? Exactly where did you notch the frame and would you happen to have a pic of that?What exactly is your WMS around 70" with a d60? Sorry for all the questions but your the only person i have found runnign the same tire combo and lift height that im after.
No prob I asked tons of questions to ...
I don't have pictures of the frame notch . The control arms will get a little rub either way but a straighter control arm in the front will give you more up travel . The control arms make contact with the frame due to there upward bend and the low lift ... So I had to use more bumpstops to avoid that . I still get 4" of up travel but could have more if you wanted it and wanted to stay low . My wms is 69" I want to go wider when I get new wheels which would help with rubbing .
#308
I have a few questions for you I also want to put 42s under mine with 3.5 lift. Did you ever take measurements of your stretch like control arms, track width and wheelbase measurements? I am on a RK 3.5 mid arm now. Do you have anymore pics of how you did your fenders and armor? Thanks!
#309
I might have more pictures buried in past post.... I have more stuff on similar threads on JKO . I do not have any exact measurements of mounting points but I took the measurements RK gave and just moved the back 2-3” and the front forward about 1-2”. Hope that helps . If you need any exact measurements let me know.
Ducttape4all (12-11-2018)
#310
Can you take the measurements of your rear control arms for me. Are they in the stock locations? My direct email is Tommygun_44@yahoo.com I am moving forward with my build right now. Thank you!!
