special tools, equipment for neighborly use
1 Post
special tools, equipment, facility or service for neighborly use.
if you have specialty tools or equipment or facilities that you would like to share as a neighborly jeep gesture please post in this method below
AREA: la la land area, Ontario
ITEMS: tourqued up spindle converter....helps set spindle load and converter release
spring compressor large air compressor.
SERVICES: recovery services pm me if you head out somewhere during the week i could be available for standby recovery if you need it with in the area
FACILITY: land to practice recovery methods.
methods of use to be negotiated amongst lender and borrower.
no fees although offering are permitted.
details to be arranged in PMs
nothing else should appear in this thread accept for offerings.
1 Post
AREA: Quinte area
ITEMS:
scan gauge 2 - for diagnosing jeep codes.
110v flux mig welder with a generator for portable welding
trailer 4x8, 4 pin, with hitch for 2" receiver or with out for 1 7/8" ball
axle stands
120v impact wrench
dremel tool with 1000pcs
sawzall
grinder
NYLON V-CHAIN BRIDLE WITH 2FT LEGS AND R,T, FORGED J HOOKS , AXLE STRAPS true tow truck recovery hook ups, works with any vehicle
SERVICE:
recovery standby
maintenance truck mobile tool chest to help fix your break down issue
FACILITY:
recovery training area
test drive area/ proving ground.
contact via PM or email in advance of requirement
email ///scottgsmith@gmail.com
cell 6139228090
ITEMS:
axle stands
120v impact wrench
sawzall
grinder
SERVICE:
recovery standby
FACILITY:
cell 6139228090
Area Hamilton
Cutting torch
Grinder
Chop saw
drills
220 mig
110 arc
jack stands
forklift Handy kinda like a hoist lol
Impact gun electric and air
compressors
air sanders and electric
electric metal shear great for body mods
reciprocating saw
Sledge hammer
16 ton TUBE BENDER IS HERE YAA
Not sure what else lol
lots of room to work
Dry concrete floor
Just respect facility and tools thats all
Recovery help always if i can make it
Cutting torch
Grinder
Chop saw
drills
220 mig
110 arc
jack stands
compressors
reciprocating saw
Sledge hammer
Dry concrete floor
Kingston Area:
IF you are going to be wheeling and you havent called me you areo n your own
Seriously though if someone is in a bind send me a PM and I will try to help.
Area: Barrie
Items
A wall of tools too much too mention
sets of sockets
sets of wrenches
Jack Stands
floor jack
Sander
sawzall
grinder
table saw Chop saw
drills/hammer/battery
compressor
Services
recovery
If you need help or are in the area let me know Cell is on all hours
scbesse@sympatico.ca
705-321-3667
Items
sets of sockets
sets of wrenches
Jack Stands
floor jack
Sander
sawzall
grinder
table saw Chop saw
compressor
Services
recovery
705-321-3667
Bowmanville Area:
pry bars
more screw drivers then I can count
multiple sets of sockets
multiple sets of wrenches
floor and hi-lift jack
jack stands
spring compressors
electric 1/2 impact gun
hammer drills/drills/hammers
sawzall
grinder
table & chop saws
If you are in the area and need any help or a recovery feel free to give me a shout 647-294-0834. Cell is always on.
pry bars
jack stands
spring compressors
sawzall
grinder
table & chop saws
Area: Milton
I don't have a whole lot of tools or any specialty tools, but willing to help out where I can. Like fetching beer or holding lights etc...
Jack stands
Sawzall
Drills
most basic tools.
Mike
Jack stands
Sawzall
Drills
most basic tools.
Mike
Ottawa/Gatineau area (Buckingham sector).
Usual socket/wrench sets in spades some of the not so common items.
Male hex key impact socket set.
1" drive ratchet and various larger sockets to go with it.
3/4" drive swivels 5 or so of em.
450 ft/lbs 3/4" impact gun (air).
Orbital sander (air).
High lift Jack & Jack stands (2 8 tons & 2 2 tons).
Compression tester.
Giant sized with various configured pry bar set.
Setaline torch (not oxysetaline).
Plasma cutter (Hypotherm Powermax 600).
4 Kilowatte portable Generator.
75ft extentsion cord with a dryer male plug end and the typical 220v famale end for stuff that needs high amperage 2 phase 220v applications.
Electronic tester.
Easy to use fuel syphoner (metal ball bearing type)
Gas/Fuel rail pressure tester with various adapters.
BMW code reader that is good for all models from 1984-2002 (to add I am a BMW guru with plans to expand into a Jeep guru as well).
Choker and chains (for pulling logs)
Chainsaw (Sthil) I come with it!
SQUBA gear including a dry suit for when the real deep recoverys are needed.
You would be very surprised how much weight air in a garbage bag which is also inside an onion bag can bring up to the surface.
Sure I have more but that's all that is comming to mind @ the moment.
Compression tester.
Electronic tester.
