Anything & Everything General discussions about pretty much anything and everything under the sun EXCEPT for topics specifically regarding the Jeep JK Wrangler. Please note that posts made in this forum will NOT be added to your overall post count. Also, be advised that the content allowed within this forum may be considered by some to be R-Rated in nature and is intended for mature adults only. If you are offended easily, please exercise some personal restraint and refrain from visiting this sub-forum. DO NOT start threads which encourages the posting of sexually-oriented photos and or content.
plz help asap! 99 Jeep Wrangler tj re gear
Old 12-04-2012, 10:36 PM
muddler!'s Avatar
Default plz help asap! 99 Jeep Wrangler tj re gear
I have a 99 tj 4.0L with the 3 speed auto no od, I'm running 36in tires and can't decide what great ratio to go with, I went from 3.73s to 4.88s and that was way to low to run on the highway and the 3.73s where to high any suggestions on a good between gear for my daily driver/4x4???
muddler! is offline
Old 12-04-2012, 11:22 PM
mook8651's Avatar
Any gears you put in it are going to be horrible on gas with that tranny an running those tires. Best bet would be 4.10 or 4.56 if you can find them. What rear end do you have the 35 or 44?
mook8651 is offline
Old 12-04-2012, 11:32 PM
OJK12's Avatar
I agree I'd go 4:10 if you say 4:88 was way to low then 4:56 may still be too low for you 4:10 is pretty low, plus you could add a rubicon tcase if want low gears offroad and good highway gears on road.
OJK12 is offline
Old 12-05-2012, 12:04 AM
muddler!'s Avatar
It has the 35..... I really wish it was a 44
muddler! is offline
Old 12-05-2012, 12:20 AM
muddler!'s Avatar
I'm ordering the gears new so I don't have to worry about finding them, I was thinking about going with Yukon gears I've never herd anything bad about them, anyone have a preference that I should look into?
muddler! is offline
Old 12-05-2012, 12:29 AM
mook8651's Avatar
I'd watch going anything over 4.10 in the 35 cause you start getting the pinion teeth real thin an have a good chance of grenadine the rear end. I'd try to find a 44 cause even with the 3.73 under load off roading that 35 won't hold up to well. The best of both world is hard to find in a jeep it's either bad ass off roading or mall crawling. You have to sacrifice one for the other!
mook8651 is offline
Old 12-07-2012, 02:05 PM
havochaos's Avatar
I can look Monday and see if we have a 44 for it.
havochaos is offline
Old 12-07-2012, 03:36 PM
medburd's Avatar
Maybe consider the 8.8 upgrade if you really want to dump that d35. I have a 99 w/4:10's. i also have 33's , the difference is mine is a 5 speed. Gearing is always going to be odd on the highway... I find the 4:10's and 33's a bit underpowered on the highway w/the 5 speed. But I wouldn't hesitate to throw 35's on it and keep the gearing as is. Funny around town, all the gearing I'll ever need. Its an under 75 mph vehicle...
I'm under the impression 4:10's were pretty common on the 4cyl's.. That might be an option for ya, front n back bolt on assemblies and sell yours off for some cost recovery.
medburd is offline
Quick Reply: plz help asap! 99 Jeep Wrangler tj re gear
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
