Anything & Everything General discussions about pretty much anything and everything under the sun EXCEPT for topics specifically regarding the Jeep JK Wrangler. Please note that posts made in this forum will NOT be added to your overall post count. Also, be advised that the content allowed within this forum may be considered by some to be R-Rated in nature and is intended for mature adults only. If you are offended easily, please exercise some personal restraint and refrain from visiting this sub-forum. DO NOT start threads which encourages the posting of sexually-oriented photos and or content.
tire measurement diffs?
Old 09-11-2006, 05:33 PM
Default tire measurement diffs?
Can someone explain the difference in tire sizing between the metric (ex: 255/75R17) and the SAE/American/whatever (ex: 33X9.5QR15) to me? When speaking of putting 33s on, does that translate to a metric-type tire, or does it have to be the other measurement (like 33"x whatever)? Thanks.
luna95 is offline
Old 09-11-2006, 08:41 PM
JK-Forum Founder
Okay, when you see 255/75R17, the 255 is the measured width of the tire tread in millimeters. The 75 is the ratio or percent of sidewalls in relationship to the tread width. In other words, the height of the side walls is 75% the width of 255mm. The R stands for radial construction and 17 is the diameter of the wheel it's mounted to.
In its practical sense, a 255/75/17 tire really equals = 32.1x10/17
Typically, most tires made for a 16" wheel or larger will come in metric. Does that make sense?
wayoflife is offline
Old 09-12-2006, 08:28 AM
jeez...little did I know that I'd be learning higher math on a jeep forum.:rolleyes: Thanks, though. I did know that about the metric, I just wondered why people don't say, "...and I'm gonna stuff some 295/85s in the wells", instead of saying 35s or whatever, y'know?
I guess what I was trying to ask was why with Jeeps and 4x4s in general, people talk about the American dimensions of the tires, and if there is any difference, ultimately in what I order (probably gonna get BFG all terrain T/As).
For example, I have a 350z, and recently got some new treads in the back...they are 18" wheels, but I never saw anything referenced in terms of inches as far as the actual tire went. They are 245/40 18s. Not to belabor the point, I just wanna make sure I'm getting the right thing.
luna95 is offline
Old 09-12-2006, 08:59 AM
JK-Forum Founder
:o LOL!! I apologize for the unwarranted tire lesson.
As far as why Jeep/Off-Road vehicle guys refer to tires in inches go.... I have no idea other than the fact that it's easier to get an idea of what were talking about.... comparing apples to apples kind of thing. As you know, common off road tire sizes in the standard 15" wheel variety have always been 31's, 32's, 33's, 35's etc. and so when you say something like "I got me a set of 285/75R17", it's harder to get a feell for how that would compare with what most of us have on our Jeeps now. That is of course, unless you knew what it's conversion is
Old 09-12-2006, 07:12 PM
shoot, that's all you, brotha. look at you converting metrics to decimals. that's why i dropped calc III.:confused:
really, though, thanks. much better to get more info than less.
btw, after looking at the pix from your test drive, now i KNOW i'm doing the right thing by putting some 33s on.
luna95 is offline
Old 09-16-2006, 10:01 PM
Why worry about math when we have the WEB for a resource. Check out Procomp Tire's site and you'll find a tire size conversion calculator. Just go to www.procomptire.com and click on any of the tire images. Then at the top of the pave you'll see header boxes, the far right light-blue box says converersion chart. Click on this and can check any P-metric tire size and get a standard size conversion to compare. I'm sure you can search out other conversion charts on the web.
Remember that almost every tire maker rounds up from the decimal point, so a 34.5 dia tire will be sold as a 35.
Jeepminded is offline
Old 09-22-2006, 07:52 AM
Ge99ne's Avatar
You beat me to the punch jeepminded. I was going to say that the inches height system is similar to the magic they use sizing crt monitors. It seems like tires fall shorter than a half inch in most cases, when compared to the claimed size. More like if it's an 1/8 bigger than 32, then it's a 33.
Ge99ne is offline
Old 09-22-2006, 10:59 AM
CJ2a's Avatar
With cars, there are a lot of variables you need to fit. With 4x4 tires, it's almost always been about HEIGHT. Back in the day, you only had 15" wheels (or 16.5" if you drove a 1 ton truck) And all the tires came sized:
DIAMETER x WIDTH - RIM
We soon got to put the 'R' in for radial, but many of the best tires of the day were bias ply. And let me tell ya, the above sizes were a lot better than seeing a size of:
Q78-16
Which is one of the more popular 35-36" Super Swamper Tires, but was a popular size method for large tires up to the early 80's.
Or even
600-16
Which of course is the tire size of the original Willys CJ2a.
Now, with the metric sizing, you get a lot of information, but you have to piece together several items to get an idea of just how tall we are talking. And even then it is just an estimate as the actual sizes can vary greatly. No matter what you want, it's best to go find the manufacturer's true size chart for more accurate dimentions.
CJ2a is offline
Quick Reply: tire measurement diffs?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
