special tools, equipment for neighborly use
special tools, equipment, facility or service for neighborly use.
if you have specialty tools or equipment or facilities that you would like to share as a neighborly jeep gesture please post in this method below AREA: la la land area, Ontario ITEMS: tourqued up spindle converter....helps set spindle load and converter release spring compressor large air compressor. SERVICES: recovery services pm me if you head out somewhere during the week i could be available for standby recovery if you need it with in the area FACILITY: land to practice recovery methods. methods of use to be negotiated amongst lender and borrower. no fees although offering are permitted. details to be arranged in PMs nothing else should appear in this thread accept for offerings. |
AREA: Quinte area
ITEMS: scan gauge 2 - for diagnosing jeep codes. 110v flux mig welder with a generator for portable welding trailer 4x8, 4 pin, with hitch for 2" receiver or with out for 1 7/8" ball axle stands large air compressor 120v impact wrench dremel tool with 1000pcs sawzall grinder NYLON V-CHAIN BRIDLE WITH 2FT LEGS AND R,T, FORGED J HOOKS , AXLE STRAPS true tow truck recovery hook ups, works with any vehicle SERVICE: recovery standby maintenance truck mobile tool chest to help fix your break down issue FACILITY: recovery training area test drive area/ proving ground. contact via PM or email in advance of requirement email ///scottgsmith@gmail.com cell 6139228090 |
AREA: Ottawa area (Barrhaven)
ITEMS: Scan Gauge II - For pulling automotive codes. Large Torque wrench (for torquing wheel nuts) Cheap Set of axle stands |
Area Hamilton
Cutting torch Grinder Chop saw drills 220 mig 110 arc jack stands forklift Handy kinda like a hoist lol Impact gun electric and air compressors air sanders and electric electric metal shear great for body mods reciprocating saw Sledge hammer 16 ton TUBE BENDER IS HERE YAA Not sure what else lol lots of room to work Dry concrete floor Just respect facility and tools thats all:thumbsup: Recovery help always if i can make it |
Kingston Area:
IF you are going to be wheeling and you havent called me you areo n your own ;) Seriously though if someone is in a bind send me a PM and I will try to help. |
Area: Barrie
Items A wall of tools too much too mention sets of sockets sets of wrenches Jack Stands floor jack Sander sawzall grinder table saw Chop saw drills/hammer/battery compressor Services recovery If you need help or are in the area let me know Cell is on all hours scbesse@sympatico.ca 705-321-3667 |
Bowmanville Area:
pry bars more screw drivers then I can count multiple sets of sockets multiple sets of wrenches floor and hi-lift jack jack stands spring compressors electric 1/2 impact gun hammer drills/drills/hammers sawzall grinder table & chop saws If you are in the area and need any help or a recovery feel free to give me a shout 647-294-0834. Cell is always on. |
Area: Milton
I don't have a whole lot of tools or any specialty tools, but willing to help out where I can. Like fetching beer or holding lights etc... Jack stands Sawzall Drills most basic tools. Mike |
Ottawa/Gatineau area (Buckingham sector).
Usual socket/wrench sets in spades some of the not so common items. Male hex key impact socket set. 1" drive ratchet and various larger sockets to go with it. 3/4" drive swivels 5 or so of em. 450 ft/lbs 3/4" impact gun (air). Orbital sander (air). High lift Jack & Jack stands (2 8 tons & 2 2 tons). Compression tester. Giant sized with various configured pry bar set. Setaline torch (not oxysetaline). Plasma cutter (Hypotherm Powermax 600). 4 Kilowatte portable Generator. 75ft extentsion cord with a dryer male plug end and the typical 220v famale end for stuff that needs high amperage 2 phase 220v applications. Electronic tester. Easy to use fuel syphoner (metal ball bearing type) Gas/Fuel rail pressure tester with various adapters. BMW code reader that is good for all models from 1984-2002 (to add I am a BMW guru with plans to expand into a Jeep guru as well). Choker and chains (for pulling logs) Chainsaw (Sthil) I come with it! SQUBA gear including a dry suit for when the real deep recoverys are needed. You would be very surprised how much weight air in a garbage bag which is also inside an onion bag can bring up to the surface. Sure I have more but that's all that is comming to mind @ the moment. |
Downtown Toronto - if you need help with a CB install/tune - happy to help.
Multimeter SWR Meter |
