Cooking & Grilling General discussion forum regarding kitchen cooking and BAR-B-Q Grilling.
Best Hard Boiled Egg, Help!
Old 05-06-2009, 08:34 PM
CIJeep's Avatar
Originally Posted by toad
OMG..just put them in water..bring to boil for about 10 mins and they are done. It's just that easy.
LOL, he breaks them, so I'd say do the above....but put the eggs in the pan 1st, then fill with water and boil. Load it with salt it will raise the boiling point and quick seal cracks should they develop.
Old 05-06-2009, 11:44 PM
bluerubicon08's Avatar
Originally Posted by muddpuppy01
eggs water burner on boil till eggs dont keep spinning
spinning test take egg put it on the counter then spin it stop and let go real qiuck raw egg keeps spinning boiled egg stops
Dude! You're just not right!.......and to do that to a fellow Jeeper!
Old 05-07-2009, 07:56 PM
Audiophiliac's Avatar
I boil the water. Add the eggs. 15 minutes. Cold water to cool them. They peel easy and are not green. I will try the salt/vinegar trick...but mine mostly come apart in a few large chunks of shell.
Old 05-22-2009, 03:14 AM
Wings fan's Avatar
We start with the water boiling ease the eggs in for 7 min then drain them off and run under cold water. Never had any problems, if you have xl eggs you many go 8 min.
Originally Posted by jkJason
Your body only absorbs around 40g protein at a time so it's best to eat constantly throughout the day rather than huge amounts 3x a day...but not to change the subject haha I will try salt thanks.
Everyones body is different and can assimilate protien at a different rate. To find out how much your body can handle start at 40g every two to 3 hours. The gage is your farts if you have the horrible swamp gas farts that hang around for what seems like 10 min or more with out going away, you've hit the limit of your protien intake. Otherwise keep going, the though just like the Animial pack vitamins if your not going past the amount your body can handle then your not getting to the max it can handle.
Old 12-12-2013, 11:13 PM
Chefbrujo's Avatar
Perfect boiled eggs:
1) pot, water, small towel, eggs. Towel is used to keep the eggs from cracking as the water boils and rolls them around
1a) salt and/or vinegar in the water is bs and does not contribute to success of cooking eggs or of peeling them. It simply adds a salinity and/or acidity, both of which contribute to denaturing the egg protein in the event the shell cracks and egg escapes. It helps keep the egg in the shell because it "cooks" it as its escaping. Kind of a self-healing type of thing.
2) start all from room temp/cold and bring to a boil. You need to watch near the boiling point so u can accurately time the whole process.
3) as soon as water boils start timer for 11 minutes.
4) have an ice bath ready to shock the eggs immediately after 11 minutes is up.
5) transfer eggs immediately into ice water. I usually put pot of boiling water under cold tap water until tap has replace boiling water and eggs can be grabbed by the hand and put in the ice bath. (It takes about 30 seconds cold tap water to do this) let the eggs sit in the icebath for at least 10 minutes.
6) perfect boiled eggs.
Old 12-13-2013, 04:32 PM
island girl's Avatar
Add a teaspoon of baking soda to the water it makes the eggs peel very easy
Old 12-13-2013, 07:40 PM
HappyJK's Avatar
Wow. Old thread.
I found the best method (was close to what was said already), put eggs in cold water (add salt or vinegar if you want), bring up to boil for 1 minute, then shut off. Cover pot and let sit 15 min. This will keep the eggs from over cooking. At 15 min. cool down quickly in cold water/ice water.
Perfect eggs with less cooking.
Old 12-13-2013, 08:49 PM
JKZinger's Avatar
Also, buy your eggs one week in advance before cooking and they will peel easy. Super fresh eggs don't peel well at all.
Old 12-13-2013, 09:44 PM
rsbmg's Avatar
Take eggs put them in pot, fill it with water turn it on go watch tv come back whenever you want prior to all the water boiling out of the pot. put the egss in the fridge, when you want to eat one take it out and peel it.
Old 05-16-2018, 03:26 PM
KimJeepJK's Avatar
Best way is through this thing on Amazon - https://www.amazon.com/Dash-Rapid-Egg-Cooker-Scrambled/dp/B00DDXWFY0/ref=sr_1_3?ie=UTF8&qid=1526513170&sr=8-3&keywords=egg+boilerIt doesn't matter if the shells are fresh or old - they peel beautifully every time.
Quick Reply: Best Hard Boiled Egg, Help!
