JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Cooking & Grilling (https://www.jk-forum.com/forums/cooking-grilling-131/)
-   -   Makin bacon (https://www.jk-forum.com/forums/cooking-grilling-131/makin-bacon-354460/)
Dat Jul 29, 2020 09:28 AM
Makin bacon
First time to cure bacon, I've made Canadian bacon, corned beef, pastrami and ham, but this was my first go around with a fresh pork belly
Dat Jul 29, 2020 09:33 AM
https://cimg8.ibsrv.net/gimg/www.jk-...0b615fcc70.jpg
Dat Jul 29, 2020 09:34 AM
https://cimg3.ibsrv.net/gimg/www.jk-...71d74ba491.jpg
Dat Jul 29, 2020 09:36 AM
https://cimg9.ibsrv.net/gimg/www.jk-...78ff629c0a.jpg
Dat Jul 29, 2020 09:37 AM
https://cimg4.ibsrv.net/gimg/www.jk-...9ec9958bd8.jpg
Dat Jul 29, 2020 09:40 AM
It takes about a week or so of curing time, then about 5 hours of low heat smoke, but it is sure worth the time once you fry some up
resharp001 Jul 29, 2020 09:57 AM
Man, making me hungry. I've never really looked at the process, but I would have thought it would take longer than a week to cure. Is that just a week in the fridge?
karls10jk Jul 29, 2020 10:18 AM
This is on my list to do. I've got a vacuum sealer so it should cut down the time for curing or make it super intense- not sure which. The other thing is the low smoke. I have wood and a small charcoal grill but I've seen where you can make it work if you do some crazy charcoal patterns and use wood chips.
resharp001 Jul 29, 2020 10:26 AM
Karl, what size grill do you have? My primary smoker is a Cookshack Smokette.....a little electric smoker that I've had for well over a decade now and is great. It's so easy that the spousal unit can use it. It replaced a Weber Bullet that was just too much work. The one thing I miss with the Smokette is you don't get the same combustion, so no smoke rings, but the flavor is great and the easy is set-it-and-forget-it for the most part, a la good ole Ron Popeil. Anyhow, I digress. I ask because I use a Weber kettle for most normal grilling. I finally decided to buy a Slow N Sear for that, which allows a lot of versatility for smoking things, more like a traditional smoker. I've figured it would be great for some jobs that are in the 4-5 hr range, and also for jobs that my electric smoker can't get hot enough to get a bark on something in a short amount of time. I do a lot of sous vide cooking as well and just need to get a nice bark in 2-3 hours sometimes.
I have seen the old "snake" method of charcoal as well which does keep things going at a low temp over time, but does need a little maintenance along the way.
Dat Jul 29, 2020 11:25 AM
Cure time is 7 days per inch thick, I cured it 8 days, I didn't measure, but it was a little over an inch thick,
Morton tender quick or Morton sugar cure, which is still a salt cure even though it says sugar,
brown sugar
Black pepper
Molasses or maple syrup
One tablespoon per pound of each, in a ziplock bag in the fridge, turn once a day for the 7 days per inch, for how ever thick.
I smoked on a pit boss pellet smoker on 150, I call that a low heat even though it isn't a "cold smoke" as much .
Not sure how a vacuum sealer would work on curing, probably would be ok, but I like to swish it around every time I turn it
© 2026 MH Sub I, LLC dba Internet Brands
