2008 jk missfire p0306
Hi guys and girls
i have a 08 jk 3.8 with a p0306 code miss fire # 6 had the motor rebuilt last week complete rebuild changed plugs wires coil and injector also crank sensor and cam sensor . checked wiring to injector all good .put a old plug in the # 6 wire and good spark cleared the code and came back moved the plug to another cylinder and same code ??? im lost on what to do anyone have this problem ? thanks
Misfire codes are hard to troubleshoot because anything that causes the crankshaft to slow when the computer thinks it should be speeding up (as when the fuel/air mixture burns) will set the code.
It's not necessarily a true misfire.
Here is a list of things to check for any of the misfire codes:
P0300-P0306 CYLINDER MISFIRE
· When Monitored:
Any time the engine is running, and the adaptive numerator has been successfully updated.
· Set Condition:
The threshold to set the fault is application specific; it is tied to the level of misfire that will cause emissions to increase to 1.5 times the standard or in some cases 1%. It is always a two trip fault above the calibrated RPM. It takes 1 soft fail to set a malfunction and two trips to set the MIL. Three good trips to turn off the MIL.
[TABLE="class: MsoNormalTable"]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD="width: 452"] ASD RELAY OUTPUT CIRCUIT
[/TD]
[/TR]
[TR]
[TD="width: 452"] INJECTOR CONTROL CIRCUIT
[/TD]
[/TR]
[TR]
[TD="width: 452"] COIL CONTROL CIRCUIT
[/TD]
[/TR]
[TR]
[TD="width: 452"] IGNITION WIRE
[/TD]
[/TR]
[TR]
[TD="width: 452"] SPARK PLUG
[/TD]
[/TR]
[TR]
[TD="width: 452"] IGNITION COIL
[/TD]
[/TR]
[TR]
[TD="width: 452"] FUEL PUMP INLET STRAINER PLUGGED
[/TD]
[/TR]
[TR]
[TD="width: 452"] RESTRICTED FUEL SUPPLY LINE
[/TD]
[/TR]
[TR]
[TD="width: 452"] FUEL PUMP MODULE
[/TD]
[/TR]
[TR]
[TD="width: 452"] FUEL PRESSURE LEAK DOWN
[/TD]
[/TR]
[TR]
[TD="width: 452"] FUEL INJECTOR
[/TD]
[/TR]
[TR]
[TD="width: 452"] ENGINE MECHANICAL
[/TD]
[/TR]
[TR]
[TD="width: 452"] POWERTRAIN CONTROL MODULE (PCM)
[/TD]
[/TR]
[/TABLE]
VISUAL INSPECTION
NOTE: Anything that affects the speed of the crankshaft can cause a misfire DTC.
NOTE: When a Misfire is detected for a particular cylinder, the PCM will shut down that cylinder's Injector Control circuit.
Turn the ignition off.
- Visually inspect the engine for any of the following conditions.
- Worn serpentine belt
- Binding Engine-Driven accessories: A/C Compressor, P/S Pump, Water pump.
- Misalignment of the Water pump, P/S Pump and A/C Compressor pulleys
- Corroded PCM power and ground circuits.
- Improper CKP, CMP, MAP, and TP Sensor mounting
- Poor connector/terminal to component connection. i.e., CKP sensor, Fuel Injector, Ignition coil, etc.
- Vacuum leaks
- Restricted Air Induction system or Exhaust system.
- Internal engine component failures.
SPARK PLUG
Remove the Spark Plug.
Inspect the Spark Plug for the following conditions.
- Cracks
- Carbon Tracking
- Foreign Material
- Gap size out of specifications
- Loose or broken electrode
NOTE: Lightly tap the bottom of the spark plug on a solid surface. The electrode in the spark plug should not move.
ENGINE MECHANICAL
Check for any of the following conditions/mechanical problems.
ENGINE VACUUM - must be at least 13 inches in neutral
ENGINE VALVE TIMING - must be within specifications
ENGINE COMPRESSION - must be within specifications
ENGINE EXHAUST SYSTEM - must be free of any restrictions or leaks.
ENGINE PCV SYSTEM - must flow freely
TORQUE CONVERTER STALL SPEED - must be within specifications
POWER BRAKE BOOSTER - no internal vacuum leaks
FUEL - must be free of contamination
CAM LOBES - must not be worn excessively
CYLINDER LEAKAGE TEST - must be within specifications
VALVE SPRINGS - cannot be weak or broken
Using the wiring diagram/schematic as a guide, inspect the wiring and connectors between the related Sensor, Coil, Injector, and the Powertrain Control Module (PCM).
Look for any chafed, pierced, pinched, or partially broken wires.
Look for broken, bent, pushed out or corroded terminals. Verify that there is good pin to terminal contact in the related Sensors, Coils, Injectors, and the Powertrain Control Module connectors.
Refer to any Technical Service Bulletins that may apply.
· When Monitored:
· Set Condition:
[TR]
[TD]
Possible Causes
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
VISUAL INSPECTION
- Vacuum leaks
SPARK PLUG
- Cracks
- Carbon Tracking
- Foreign Material
ENGINE MECHANICAL
