Stock JL Tech Bulletin board forum regarding issues with OE (original equipment) components of the Jeep JL Wrangler (Rubicon, Sahara, Unlimited and X) such as factory suspension parts, engine, transmission, body parts, interior fixtures and the on-board computer.
JL New Products by Icon Vehicle Dynamics
Old 03-25-2018, 10:43 AM
Former Vendor
Icon_Fred's Avatar
Default JL New Products by Icon Vehicle Dynamics
2018 Jeep JL 2.5" Icon System with 17" Icon Alloys Alpha wheels in Bronze
2018 - UP JL 2.5" Suspension System
PRODUCT PREVIEW 2018-UP Jeep Wrangler JL 2.5" Suspension System
KEY FEATURES
  • 2.5" lift height
  • Fits 35" tires (37" with bump stop spacer kit)
  • 3" front, 2" rear increase in wheel travel
  • Improves on and off-road ride quality over stock
  • Dual rate coil springs with lifetime guarantee against sagging/breakage
  • 2.0 Aluminum Series shocks with vehicle specific valving
  • 100% bolt-on system makes for an easy install
  • “ICON 1K” tested under rigorous off-road conditions to validate tune, performance, strength, and durability
WHEEL & TIRE FITMENT INFO:
  • OEM Wheels & Tires: Yes
  • [NON-RUBICON] Aftermarket Wheels: 8.5″ Wide, 4.5″ Backspace
  • [NON-RUBICON] Aftermarket Tires : 35" x 12.50 (Larger tires will fit with recommended bump stop spacer kit and minor trimming)
  • [NON-RUBICON] Recommended Wheel: ICON Alloys 'Rebound' 17x8.5 / 4.5" BS / -6mm Offset
  • [RUBICON] Aftermarket Wheels: 8.5″ Wide, 4.75″ Backspace
  • [RUBICON] Aftermarket Tires: 35" X 12.50 (37" tires will fit with recommended bump stop spacer kit)
  • [RUBICON] Recommended Wheel: ICON Alloys 'Alpha' 17x8.5 / 4.75" BS / 0mm Offset
ICON Vehicle Dynamics is excited to provide a sneak-peek into the development of a 2.5” suspension system for the new 2018 Jeep Wrangler JL. Aimed at drastically improving (not just maintaining) on and off-road ride quality this system includes dual rate coil springs, 2.0 Aluminum Series shocks, link arms, front and rear bump stops, sway bar end links, and all necessary hardware for a complete install. The JL is a much more “refined” vehicle compared to previous Wranglers, and with improved suspension geometry and more robust components this new Jeep sees significant performance gains with the introduction of ICON suspension products.
Through an accelerated testing process dubbed the “ICON1K” R&D program, ICON has logged over a thousand miles in the dirt pushing the JL to off-road extremes to identify limiting factors in OE components, develop products that remove these limits, and further extrapolate performance out of this vehicle. This 2.5” suspension system has been tweaked, tuned, and revised several times over the course of this ICON1K testing in an effort to provide unparalleled ride quality and vehicle dynamics for everything from rock crawling to high-speed desert running. By removing the aforementioned “limiting factors” this ICON suspension system completely redefines the potential of the 2018-UP Jeep JL with wheel travel gains over 30%!
This ICON Vehicle Dynamics 2.5” suspension system will allow for the use of a 35” tire, while ICON Alloys offers wheels in both a 4.5” and 4.75” backspace that provides ideal fitment for the varying axle widths found on Rubicon and non-Rubicon models. For those who are looking to install a 37” tire, ICON will be offering a bump stop spacer kit that allows for this as well. Additional ICON JL components are currently in development, so be sure to keep your eyes out for an official release on the COMPLETE 2.5" suspension system lineup in the coming weeks!
Holistic Engineering - the ICON Difference
When developing suspension components for a new vehicle, ICON takes a different approach than many others. Rather than focusing in on one particular part, ICON engineers look at the vehicle as a whole, identify inherent strengths and weaknesses, and set a target for performance. With a focus on maximizing wheel travel and improving ride quality, ICON will develop components that address (and often times replace) OE limiting factors. This "holistic engineering" philosophy often results in the development of several parts designed to work together as a system to provide a balanced on and off-road performance upgrade. Because ICON is designing and manufacturing all of the components necessary to improve the performance of a vehicle from front to back, end-users can rest easy knowing they are dealing with ONE manufacturer, ONE standard of quality, and ONE awesome warranty to back it all up.
ICON Vehicle Dynamics products are proudly designed, manufactured, and assembled in Riverside, California by a team of passionate off-road enthusiasts. With a reputation for quality, performance, and service it's clear that ICON Vehicle Dynamics is the top choice for performance suspension systems and shock absorbers for the new Jeep Wrangler JL.
Quick Reply: JL New Products by Icon Vehicle Dynamics
