Jeep Recycler If you've got a Jeep that you want to sell or are interested in buying a used one, this is the forum for you.
2008 Supercharged Jeep Wrangler X Low Miles
Old Feb 20, 2015 | 11:32 AM
RedneckRhino's Avatar
Default 2008 Supercharged Jeep Wrangler X Low Miles
Make me an Offer a decent offer.
Due to undesirable circumstances I have to part ways with my Jeep. I'm asking 24,000 Or Best Offer. This Jeep has been babied, never abused, and due to other circumstances it has not been off road but twice in novice conditions. I have a lot more pictures if you are interested.
For sale is a 2008 Supercharged Jeep Wrangler X. This vehicle has been in PA for 6 months, so as you can see in the pictures there is 1% rust if that. NO BODY RUST, NO DOOR PANEL RUST, NO RUST ON FRAME.
The BASICS:
ASKING 24,000 MAKE ME AN OFFER
The Jeep is inspected until 11/15.
It has Manual locks, windows, seats (seats are cloth), carpet is clean, radio, A/C, HEAT works, and oil has been changed every 3000 miles with CASTROL HIGH PERFORMANCE.
There are no rips, tears, or anything close to abuse or misuse on the interior.
The exterior has a few minor scratches, though I'd have to point them out for you to notice.
63,646 Miles
3.8L V6 with 6 Speed Manual and Cruise Control.
17 mpg on average as seen in picture, which is minus the ability to stomp the pedal through the floorboards. HIGHWAY is about 18.4-18.8 have seen 19.2 a few times when it is warmer out.
Engine:
BANKS Ram Air Intake System
Rugged Ridge Throttle Body Spacer Kit
RIPP Supercharger kit, Stage 2 V3-SI Trim, Intercooled w/ EXTRA Blower Oil and Belts less than 2500 miles on Supercharger Kit
RIPP Long Tube Headers w/ Cats and w/ an EXTRA pair of gaskets
Diablo Sport Performance Tuner I-1000.
MBRP XP Series T-409 Stainless Steel Cat Back Exhaust System
JK 180 Degree Thermostat
D.U.I ScreaminDemon Firepower Ignition Kit
Mean Green Alternator
Mean Green Starter
Smittybilt Dual Battery Tray (Optima's)
Rugged Ridge Dual Battery Relay Kit
Optima Red Top Battery
Optima Yellow Top Battery
Viair Constant Duty Onboard Air System
Viair 2.0 Gallon Tank Six .25" NPT ports 150 PSI Rating (Installed)
Viair 2.5 Gallon Tank Six .25" NPT ports 150 PSI Rating (Not Installed)
Dominion OffRoad JK Air Junction Box and Mount Bracket (Modified)
Dominion OffRoad JK Compressor Mount with 6 port NPT extensions w/ ALL fitments
Interior:
Uniden Bearcat 880 CB Radio w/ 7 Color display Back lighting
TeraFlex CB Antenna Mount Kit / stud w/ SO0239 Connector (Not Installed)
Rugged Ridge CB Antenna Mount (Not Installed)
Redman CB 102" Stainless Steel Power w/Stud (Installed)
Firestick Heavy Duty Stainless Steel Antenna Spring with Firestick II 4' Tunable Tip (Not Installed)
TruckSpec Side Body Mount for 3/8-24 CB Antenna (Installed)
18' RG-58/U Coaxial cable w/ PI-259 connectors
AutoMeter Gauge Works Triple Dash Pod
GlowShift Black 7 Color Gauge Air/Fuel
GlowShift Black 7 Color Gauge 60 PSI Boost
GlowShift Black 7 Color Gauge Oil Pressure
Rampage Tailgate Gas Strut Stabilizer w/ Heavy Dampener (Rear Swing Gate)
Rugged Ridge A-Pillar Switch Pod (Left/Driver Side) w/Rocker Switches - for Exterior Lights
Smittybilt G.E.A.R Black Overhead Console
Smittybilt G.E.A.R Black Tailgate Cover (Bags included)
Smittybilt Fire Extinguisher Holder
Rough Trail Deluxe Grab Roll Bar Set
Exterior and Lighting:
AEV JK Dual Sport SC Suspension 3.5/4.5" Lift Kit
AEV JK Slider (Rear Differential Skid Plate)
Tires:
5 - Goodyear Wrangler DuraTrac Tire LT315/70R17 LESS THAN 500 MILES ON THEM!!!
5 - Blackrock type 8 matte black series 997 wheels
Body Armor:
BodyArmor 4x4 Components:
High Front Clearance Bumper
Front Skid Plate
Steel Rear Bumper (Swing Arm Base)
Steel Swing Arm Tire Carrier
Steel Standard Gas Can Adapter Kit
Steel Hi-Jack Mount Kit
Black powder coated D-rings
Tail light guards
Roof Rack Base Kit
Warrior Products Cargo Rack (45"x55"x5")
Warrior Products Universal Spare tire carrier 8" spread
Warrior Products Shovel and Axe mount
Smittybilt XRC 10 winch system
Smittybilt XRC winch cover
Smittybilt license plate mount with roller fair-lead
Bushwacker flat style fender flares w/ LED turn signals
Rugged Ridge Cowl Vent Hood Scoop
Lights:
TruckLite 7" Round LED Headlamps (Very Bright)
TruckLite LED Headlamp wiring adapters
Warrior Products Windshield light brackets w/
Hella 500 Black Magic Driving Lamps w/ 12V 50Amp SPST Relay and Resistor kit (Extras)
6 - LightForce 140 Lance Lights
JK Depo Smoke Rear Tail Lights
ALL OTHER LIGHTS (TURNSIGNAL, MARKERS are LED's)
Asking 24,000 Or Best Offer. Make me one
Thank you for looking, Jeep On!!
Attachment 597857
