Currie Tow Bar Mounting Plate - Skid Plate
Sold-Sold - We've changed front bumpers and our Currie Tow Bar mount/skid plate no longer fits. It's in great condition with no scratches or dings. Have all hardware and A-Arm ends that can be added to any standard A-Arm tow bracket. I've used it to pull our JK 2-3 times and it works great. The cheapest I've seen them is $199.99 plus shipping. I'll let this one go for $125.00 plus actual shipping charge. Will ship UPS. Located in Kansas City area...zip code 64060.
Here's a link to the product:
http://www.quadratec.com/products/92012_26.htm
Should work with any of the A-frame type tow bars. I have a Reece Tow Champ adjustable A-frame tow bar. They all use basically the same size square steel legs. The tow plate comes with complementary brackets that fit it and bolt on to the end of which ever tow bar you get. To answer your question...I know it will work with the Reece A-frame tow bar and the one Currie sells. They look identical. You can check out the Currie setup here:
http://www.currieenterprises.com/ces...t.aspx?id=1108
If you look at the tow bar in the picture you'll see that the brackets that are shown on the tow bar are not the ones needed to hook it to the skid/tow plate. The tow plate comes with part number CE-9033B which is shown further down the page. You remove the bracket that comes on the standard bar and replace it with CE-9033B. You can then see how it fits into the slots on the tow plate. It will also come with CE-9033P and CE-9033H and all the bolts and lock-nuts. This will be everything, along with the original instructions that you need to bolt it up.
Thanks,
David
Thanks,
David
For anyone who's interested, I'd be willing to trade this for a set of KC driving lights (100w). Don't need the wiring or relay, just the lights. Prefer the Slimlites, but will consider any.
Thanks,
David
Thanks,
David
