cb under steering wheel question
Old 11-30-2011, 05:13 PM
dave810's Avatar
Default cb under steering wheel question
Can some who has mounted a cobra 29 under their steering wheel help? How did you mount the cb mount bracket to that thin metal piece?
Old 11-30-2011, 05:53 PM
Paws's Avatar
What Year of Jeep do you have? Is the Cobra 29 the small formfactor or the bigger size?
I didn't mount mine to a metal bar. I screwed directly into the steering wheel cover.
As you can the i had to trim a inch off the cover to make it fit.
Old 12-01-2011, 04:07 AM
absolutalchemy's Avatar
I think it just may be too low. Getting in and out all the time, I would probably break it. But thats just me.
Old 12-01-2011, 06:25 PM
Paws's Avatar
Originally Posted by chip80
I could see some broken knee caps in a head-on collision with the radio mounted there.
If you drive like you got no balls maybe . No really my knees are on either side, but If you're in a wreck that bad its not gonna matter. I do nudge the mike from time to time and I'm 5'9", my seat is not all the way back. I would assume for the taller fellas it might be an issue. Its pretty much out of sight though and in a great location if I need to access it.
The cord does not dangle like in the pic, I have it wedged in-between the CB and steering wheel so its out of the way.
Old 12-01-2011, 08:45 PM
dave810's Avatar
I have the larger army model. I was looking at mounting it where the lowest removable plastic part is on an 07 and cutting the plastic so only about an inch would show through. There is a small metal half circle bar there I thought may work to mount the bracket to. I'm 6 foot and from where I sit I am no where near that piece.
Quick Reply: cb under steering wheel question
