Bozos on Channel 6 - who are these guys?
#41
I can't say the FCC really cares much about CB. Channel 6 is what it is no matter what state you are in. Ever since Riley Hollingsworth stepped down from his job at the FCC, the enforcement action has been stepped down. Trying to clean up the CB band is a lost cause. Most of the enforcement on CB results from CB interfering with other services or complaints of RFI.
I keep threatening to install my CB in my jeep, but I often ask myself why?
I have a 2 meter radio in the jeep and it works great on and off the trail. FM mode sounds so much better than AM.
I use my radio to talk during my commute to and from work. I never have to listen to all that junk you hear on the CB. The jeep folks I hang out with all have ham license.
The jeep clubs should make it a requirement for the members to have a 2 meter radio on the jeep runs instead of CB.
#43
damn the fcc encorcement , cut my taxes . in can always change channels and yes i hear them here in south carolina , also some guy that says HOLA ,'hola , hola like 5000 times in a row
Dat (12-31-2019)
#45
Heard these guys for the first time today after putting my CB in two days ago. It was mildly entertaining for about two minutes, then it just got annoying. The guy that says "bye bye bye" a hundred times identifies himself from Georgia. And I hear them bleeding over into other channels as well. My question is am I going to be able to transmit to the Jeep 200 hundred yards behind me on the trail with all of this going on?
#46
Just use a channel other than 6 and far enough away that you don't hear the bleed over. If you here one of those guys from channel 6 on all 40, then he's local. But if people are 200 yards away you shouldn't have trouble communicating. Turn your squelch all the way up.
#49
I actually heard this the other day too. my gf and I gave each other a pretty funny look after listening to it for a couple seconds. but anyhow. My jeep club uses channel 5, I haven't been on it for a while but I hope it doesn't bleed over into it.
#50
When I drove an 18 wheeler cross country, I hated guys like that on 19. I would end up turning my radio off for a while...and turned it back on a few times to find them still there....they were traveling the same way I was...lol
