Can i secure my antenna with thread locker?
I have a 4' firestick... is it OK to secure it with red thread locker? :thinking:
The threaded shaft is a conductor, so I'll say no. But, if you ensured that the very bottom of the antenna made good contact with the mount (which they do not, typically) you would be okay.
If you decide to try it, be sure to check your standing wave afterward. |
Originally Posted by tslewisz
(Post 2237600)
Originally Posted by bingote
(Post 2237615)
to check that standing wave... do i do that with the SWR meter?
Standing Wave Ratio = SWR |
Yes sir. Standing Wave Ratio = SWR (i speak spanish, sometimes i miss somethings :P ) |
Red threadlocker is almost permanent. Use the blue stuff if you ever want to remove.
Originally Posted by billsimcox
(Post 2238058)
(Post 2237587)
Originally Posted by RedDavid
(Post 2238396)
I use a little dab of blue. Haven't had a problem with SWR or signal quality. I used red accidentally on one, it's never coming off. Stick with the blue stuff or even purple if you use anything.
I'm guessing blue will be hard enough for thieves to quickly take the antenna but not as permanent so i can remove it if needed. |
that red stuff works don't it...???!!! :eek2:
