Can i secure my antenna with thread locker?
The threaded shaft is a conductor, so I'll say no. But, if you ensured that the very bottom of the antenna made good contact with the mount (which they do not, typically) you would be okay.
If you decide to try it, be sure to check your standing wave afterward.
to check that standing wave... do i do that with the SWR meter?
I'm guessing blue will be hard enough for thieves to quickly take the antenna but not as permanent so i can remove it if needed.
