Can i secure my antenna with thread locker?
I was also concerned about theft after installing my Firestik. I ended up heating shrink tube over the bottom of the antenna. Certainly not full-proof, but maybe enough of a deterrent.
I would steer away from thread lock myself. Good job on the heat shrink. a thief may end up twisting your mount all to hell trying to unscrew a lock-tighted antenna
A good quality "quick dis-connect"; and run the antenna only when you're in the car?
Don't forget to re-tune the antenna after you add the add'l length provided by the quick disco.
Great Idea
too bad this is not for me. I pass through the car wash once or twice a week and I have to remove antenna.... Grrrr
To Bad Its not a Perfect world..... But then again if it were perfect it would be BORING...
UV Resin information
UV Curable Adhesives or simple UV Adhesives (also referred to as Light Curing Adhesives) are single component compounds designed for precision bonding and are widely used in the manufacturing of glassware, optical devices, and medical equipment. These adhesives are preferred for industries where transparency and stability are the primary needs.
UV Resin by Parlite | UV Curable Adhesives | Windshield Repair Resin
Do you cap the open connector when going through the wash? If not water gets in and corrodes the connector and depending on which style it can trickle down to the coax and rust it out.
