cb electronic throttle interference
i need help i have a 07 wrangler i just bought a cobra i9dx iv cb radio every time i try to talk and push the button the radio throws my electronic throttle code leaving me powerless till i unplug the cb and turn the jeep off and back on any one know why this happens or any ideas. oh and jst to throw this out their i have a sprint booster on the gas pedal too i don't know if that is doing it or not but i need help
Wow man - that's scary. I would see if it happens with the Sprint booster disconnected. From what I understand, the booster sort of amplifies voltages controlling the throttle, so perhaps the RF from the CB is enough to throw things off, if the noise is further amplified.
Where are you getting power from. If you use the plug closest to the driver it is switched power. When I used this plug with a hand held and transmitted the gauges went nuts and lots of dings and lights. Using the power plug on the passenger side which goes directly to the battery I had no problems.
Just food for thought.
I tried both plug in and the same problem i amg going to take the sprint booster out and see if it still does it if it doesnt i am pluging the booster back in and taking the cb out i would rather have the booster any day of the week i will keep you informed if it is the booster
Chrysler spends a lot of money in testing of the electronics of these vehicles, and their software code and fault tree algorithm are based on this work. They do not test for stuff you add between the throttle and ECU. I would never do this with my knowledge of HIL test system and what goes into fault insertion testing.
I would loose the sprint booster, if it ever fails you could have a Toyota on your hands. Putting something between your electronic throttle just is asking for trouble.
One other thing that might help, keeping in mind that I don't know anything about the Sprint Booster. On my Cummins Dodge, I have an aftermarket power module located under the dash. When I would key up, the engine would sputter, near to the point of dying. After trying tons of things, I ended up incorporating toroidal choke cores in the wiring of the power module. Problem solved.
same thing here I can’t figure it out
