CB External speaker question???
Can you hook up a jack from the external speaker plug in a CB to the AUX jack in the factory radio to monitor the CB?
The external Microphone output from a CB is a high level output (meant to drive it's own speaker), and could potentially screw up the low level aux input on the head unit.
Just a guess though.
A little more on this....https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/aux-input-8993/
Thanks. I think I will just stick with the external speaker. I like the set up in the pics.
On a separate note, what resides behind the two "caps" that are marked "Sway bar" and "Axle Lock" if I dont have those options? I was thinking about mounting a couple of toggle switches there to control fogs and driving lights. Do those caps just pop off?
That has been covered here.......
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/blank-swith-plate-removal-6392/
