CB kills my Jeep???!!!!!!!!!!!!
Old Jan 22, 2010 | 01:14 PM
Mark Doiron's Avatar
Originally Posted by Vernnz
... BTW: what's the emoticon for sarcasm???
hxxp://news.cnet.com/technically-incorrect/?keyword=emoticon
Old Jan 24, 2010 | 05:02 AM
FJ80fornow's Avatar
I had this happen too, back when I had a Ripp SC, BUT, it had nothing to do with the Supercharger. Mine was my antenna mount that was grounded improperly...actually, At my external antenna mount, the positive side of the coax was grounding with the negative, and when I keyed the microphone, it shorted out and caused enough drain that it would sputter my engine. I am almost willing to bet (with someone elses money) that if you took a multi-meter at your antenna mount and touched both the positive and the negative, that you have continuity = bad.
Old Jan 25, 2010 | 12:49 PM
RIPPMODS's Avatar
Sponsoring Manufacturer
Thanks for the input - noted in our tech guide.
RIPPTECH
Old Jan 25, 2010 | 01:50 PM
briteod's Avatar
Thank god someone else has had this happen I was realy starting to think it was just me and bad luck!! Thanks for the help
Old Jan 25, 2010 | 02:42 PM
Matt D's Avatar
Where is the CB getting power from? What are you grounded to?
I really doubt the RF from the CB is doing anything. This has to be a current / grounding issue.
Old Jan 25, 2010 | 04:12 PM
briteod's Avatar
wired straight to pos and neg on battery tried it with a seperate battery not conected to the jeep in anyway and it still did it i have narrowed it down to the coax or the antena mount.
Old Jan 25, 2010 | 06:16 PM
Matt D's Avatar
Running the negative straight to the battery can cause a ground loop, but since you have the issue using a separate source not sure what to say. Make sure you antenna mount is grounded. Personally I would redo the negative lead, to a different point on the body (or other existing bolt) and watch your antenna cable/mount.
I have seen some crazy stuff with inductance from items that are not grounded well.
Old Jan 29, 2010 | 07:23 PM
JKGuy's Avatar
Default Power
Originally Posted by briteod
I tried a complete seperate CB system and it was okay so i poked and proded the jeep with the antenna and no death, Tried FM, AM, USB, LSB 1-40 high bands and low bands and all did it when conected to the antenna mount on the bumper disconected the mount and moved it around and as soon as i touched or got close to the bumper it died when transmiting.
Tried talking to RIPP but they keep ingnoring me im about ready to start a thread on the lack of help im getting from them. This is not the first isuue i had with my SC
If you are using "FM" and "Upper and Lower" bands then you are running an "export" radio. Depending on the model you might be putting out 200 watts or more. No wonder you have RF getting into you wiring harness. Maybe a standard radio would fix your problem.
Old Jan 29, 2010 | 10:30 PM
RevTJ's Avatar
That's really not true. Running both the negative and positive wires directly to the battery is the best way to wire a CB. It's when you have multiple ground points that you start to create a ground loop.
Old Jan 30, 2010 | 06:57 AM
briteod's Avatar
its only putting 30watts outs, plus i tried it on another one i have that barely puts 5 watts out. When i hooked up my CB completly external nothing happend until i moved the antenna close to where the mount is now and by close i mean less then a 1/4 inch almost touching.
