Cowl mount options?
That's good to know. I've also found these guys w ww.cometantenna.com. They have a bunch of lip mount antennas. But I suspect they'll have the same issue with the box frame members.
This one w ww.rightchannelradios.com/adjustable-universal-hood-mount.html
Attachment 312502
might work if there's enough of a "box" to screw it on to.
I've got an email out to these guys h ttp://cfeproducts.com/cbansys.html to see if this mount
Attachment 312504
has ever been done successfully on a jeep.
Attachment 312502
Attachment 312504
LOL. Well, good luck. If Firestik doesn't come up with a solution you might be the one to do it!
Here's pics of my aborted cowl mount job. On this first pic, you can see where I used a Sharpie to mark two screw holes in the flexible part of the quarter panel, on the right of the photo (near that square hole). You can make that piece of metal wiggle easily with your hand. With pliers you could make origami out of it.
The existing Jeep mount is a flat piece of metal, so there's no way I can work it onto that box frame member, roll it down, then bend it back out horizontally. If I had access to a metal brake, maybe.
But, notice that big bolt where the quarter panel attaches to the box frame- that area nearly matches the specs of Dodge Ram mount (Firestik posts detailed measurements of that particular mount).
More pics:
More pics:
More pics:
More pics:
Anyways gents, i decided to pull the trigger on the Arizona Ridge rear mount. Going with a 4' Firestick Firefly on a spring. The Arizona mount gets the base of the antenna up to the level of the 3rd brake light so I think it'll transmit nicely and with a 4' antenna, i think it'll work well (and look badass). I also think that the cowl mount woulda gotten hit too much on the trail by branches. Plus i was sick of looking for a cowl mount. Good luck though guys!!
Same here. The Arizona mount was my backup. I'm just worried that the antenna will be so tall that I'll have issues getting into parking garages. I'll probably throw on one of the quick disconnects in case I need to pull it off.
Otherwise it's a rear mount like the one you posted. Thanks!
EDIT: Firestik rep said they would likely work on an update, but it wouldn't be soon. Returning my cowl mount kit and going with the Arizona I think.
