ICOM IC-7000 Remote install with video on Nav System
Old 06-30-2013, 10:20 AM
maxspongebob's Avatar
Default ICOM IC-7000 Remote install with video on Nav System
I just finished the install of my ICOM IC-7000 rig in the Jeep. I love the setup, it really works well.
I went with a remote install with the radio and antenna tuner under the passengers seat and the control panel and mic on the top of the center stack.
Radio location: I installed a flat plate under the seat and attached to the bottom of it, a couple shortened computer rack rails. The radio and tuner attach to the sliding part of the rails so that I can easily pull the entire unit out from under the seat.
Control Panel: I replaced the upper center console stack with one of those Daystar units that has the tray built in. I mounted the remote control unit to the top of it so that it would sit a little lower than if I had used the factory dash. The mic is hooked to the left of the radio just on the top of the dash.
Antenna: The HF antenna (fixed frequency whip) is mounted with a ball mount on the right rear quarter panel, and the VHF/UHF is mounted on the tailgate.
Speaker: The speaker is a small 2" mounted on the rollbar in front of the overhead light.
The coolest part is that I had previously installed a LockPick to hook up a reverse camera. So I used the second video input on the LockPick to connect the ICOM's video out to the radio. The IC-7000 has a very small video screen that shows all the radio settings, it also has a composite video output so you can connect to a larger screen.
ID:	473251Click image for larger version
ID:	473252Click image for larger version
ID:	473253Click image for larger version
ID:	473254Click image for larger version
Old 06-30-2013, 11:18 AM
3Lug's Avatar
Um, Thats impressive!
Nicely done.
Old 06-30-2013, 09:40 PM
ShawnInPaso's Avatar
Wow, very slick use of the video out to the head unit.
Old 07-02-2013, 06:35 PM
JKUenvy's Avatar
That makes me wish I had sprung for the nav system - just to display the video! Nice.
Old 07-19-2013, 06:45 PM
B-MAN's Avatar
Bravo...I've been trying to figure out where to mount my rigs in the new Rubi, thanks for sharing.
Old 10-15-2017, 05:59 PM
ROADSDA's Avatar
Nice work... I did something similar to this but I have not tied in the video feed... I'll have to look at LockPick - don't know what that is.
Thought I'd share where installed my face plate, which puts all the controls in extremely convenience reach. I used an Action Pod Pro which required lifting the center console plastic around the drive select to install this mod took about 8 min total. I removed the clamp from the Action Pod and just used the hardware included. Sorry, I don't know how to rotate this images...
ID:	675524 Click image for larger version
Old 10-16-2017, 04:55 AM
CtSeaRay's Avatar
Bad ass set up man! Love it really gets me thinking about my Yaesu FT-857D upcoming install
Attachment 675524 Attachment 675525
Old 10-21-2017, 04:24 AM
DRRitchie's Avatar
Thumbs up Nice work!
Very well done! I have my Kenwood 480HX head on top of the stack, with the radio back by the tailgate. The Hi-Q screwdriver is on the tailgate. Furthest reached is Brazil on SSB. Other side of tailgate is VHF/UHF antenna for Yaesu 8900, radio tucked up under passenger footwell and head unit above rearview mirror with external speaker. Ground straps underneath and all doors. See K0BG's website on mobile.
Old 06-08-2018, 07:03 PM
Freijen's Avatar
Default Antenna
What brand of antenna and tuner did you use? I have the same setup and only have the uhf/vhf antenna installed. I also mounted the reciever under the passage seat. I mounted the remote head on a arm by the center counsel though.
Quick Reply: ICOM IC-7000 Remote install with video on Nav System
