Installed Cobra 75 and it wont turn on and my lighter isn't working
Ok, so I just got finished installing the cobra 75 along with the CoolTech UltraMount CB Antenna System and VersaMount. The problem is that the Cobra 75 won't power on! I hooked up the power to the existing leads for the right power socket. Two things one, the Cobara 75 won't turn on, and two the power socket don't seem to be working eitheir.
What do you guys think could be the problem? Could it be a fuse?
Location: Hangin in the sunshine state....staging forum..
yeah you def blew a fuse, m36 is the fuse for the power port, m6 for the lighter
the question is though why did it blow try changing it and see what happens, did you disconnect battery when you did the wiring? if not that could have caused it. You could wire the cb direct to the battery also to avoid blowing fuse.
Good Luck
p.s. you do remember that outlet only works with key on.....also its a 20amp fuse, check the inline fuse that came with your cb, just to make sure you dont need one of them before you run to store
Good Luck
I was looking at the wrong fuse, I thought it was M7. As for why it blew, can be attributed to the fact that it has a 15amp fuse in the M36 slot
Being that I am the second owner of this vehicle, I have to think it had to be him. So what does M7 go to? It says Power Port #2... Well what ever it is it is missing its fuse for the night. I will pick up some extra ones on the way to work in the morning. All I have to say is thank you tkob1060! I finished installing it at around midnight, only to find that it didn't work. So finally at 3am, which I have to say isn't bad...all issues have been resolved.
I think I am going to look the fuse box over tomorrow night and make sure very thing is in order.
P.S. Power Port #3 does not require a key It is hooked up directly to the battery, hints the little battery on the cover. However the one closest to the driver side does require a key.
Thanks Again!!!!
Thanks Again!!!!
