Just ordered Ultramount
#42
I had about a foot extra. In through the license bracket, along the driver's side under the rear window, drop down under the rear seat, forward along the center hump, hang a right under the dash and end up behind the glove box.
#45
Originally Posted by Matthewd5
Thanks for the info...
I'm sweating the details of the gate mount, specifically the ground
I'm going to be using a midland handheld
Cool tech is closed for a week of vacation so I can't ask them
Matthew
#46
Any suggestions on mounting cobra 75 mic holder onto versatile mount? Do I drill into versa mount, if so what size? The screws provided don't look self tapping
#47
The Versamount from CoolTech, or Versamount2? The former goes behind the radio, the latter behind the passenger grab bar. Mine was drilled and came with a screw/nut combo to use instead of the screws that came with the CB bracket. Yours is not drilled?
#48
Versamount 2010 jk, it is drilled for mounting through stock bolts to radio. I am asking about the cb mount for the cobra 75 do I have to drill through the exposed plate?
#50
Huh, says on the site that the Versamount comes with no holes drilled (the Versamount2 is drilled). Didn't know that. So ... mark the hole locations using the CB hanger as a template, grab an appropriate bit and go to town.
