Mounting a radio under the seat
Old Jul 17, 2011 | 06:52 AM
baudzilla's Avatar
Default Mounting a radio under the seat
I'm thinking about either a Yeasu FTM-10R or Icom IC-208H, it seems everyone is mounting their base under the front seats. How are you guys securing the base down? Are you drilling into the floor, or are there bolts already there that can be used?
Old Jul 17, 2011 | 07:58 AM
rpaulson's Avatar
I actually suspended mine with 2 75lb test zip ties so i can remove it. Once I get my tuffy trunk it's getting mounted back there to the lid
Old Jul 17, 2011 | 08:02 AM
gs2offroad's Avatar
I slipped the mounting bracket up and over the seat foam support springs such that the radio hangs below the seat bottom.
Old Jul 17, 2011 | 08:41 AM
baudzilla's Avatar
I could probably pull that off. I'm thinking about getting the besttop storage box just to secure the radio to.
Old Jul 17, 2011 | 10:36 AM
JK-jeepit's Avatar
I found a bracket off a plumbing fitting and got hardware to fit it. I don't know what the fitting was called but it was for splicing into copper pipe.. it's been in my garage for years and I'm not sure where it even can from.
Old Aug 15, 2011 | 07:32 PM
JK09's Avatar
Do you use an auto-tuner? If so, may I ask where you mounted it? Thanks!
Old Aug 15, 2011 | 07:51 PM
JK-jeepit's Avatar
Nope.... I'm not 100% but I don't think they sell tuners for VHF/UHF.
This radio is a ICOM2720.
Old Aug 15, 2011 | 08:03 PM
JK09's Avatar
Ah, ok, explains why I am having trouble finding one then!
Old Aug 16, 2011 | 07:03 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
FWIW, Mounting under the seat would be a good location.
My thinking is that should the Jeep get flooded, the radio would be compromised.
Im thinking about mounting the base unit on the drivers side behind the rear seat.
This way its out of danger of getting water damaged.
JMHO
Old Aug 17, 2011 | 08:18 AM
kd4ao's Avatar
Another good location to mount a radio with separation kit is under the steering wheel, behind the snap off plastic panel. I mounted an ICOM IC2720 there and had no problems with it.
