nobody answers back.......
OK so I hooked up my cobra 29LX and Firestik 2 tunable tip antenna (grounded directly to the frame)..... I hear ppl just fine but I don't think anyone hears me.... I just wanna make sure my radio works but I have no idea how since nobody will ever answer me back.... Does that mean that nobody can hear me?
(Post 3254853)
(Post 3254853)
I had a similar problem when I first installed mine - there was tons of chatter, too much chatter really... so when I called for a check it was hard to tell if they couldn't hear me, if someone else had talked over me, or if they were just too involved in their conversation to care to comeback. So thats when I took a short drive down the highway and was finally able to confirm. Shortly after that though I remembered that I still owned a small handheld CB, lol - all I really had to do was have my wife run into the opposite end of the house with it and check it that way :rotflmao2: |
The radio has swr meter on it and I'm one bar above 2...The guy from cobra electronics said that was fine.... And for some reason all I hear is Spanish on channel 9 and 19.....thought they were emergency channels
Channel 19 is the original "trucker channel", not really for emergency. Back when CB's were the talk of the town, all truckers went to channel 19 to talk and hear communications....
(Post 3255116)
Originally Posted by kbp810
9 is for emergencies, 19 is the standard go to trucker/highway channel; I hear some really wierd stuff on a few of the channels where I live; though 9 is always quiet and 19 seems to be filled with typical expected chatter. Thanx everybody! |
(Post 3255116)
built in SWR meter
I once had a guy be so convinced that factory meters are junk that when his stand alone meter matched my built in, he went inside to borrow a meter from the other repair tech. When it matched the two previous readings he said there was probably a ground problem or it was a bad anntena and I needed to move it off the trunk lid so it would ground directly into the body before he could properly test it. I never returned.
Originally Posted by Suspector X
(Post 3277905)
