Regular or Flex?
Regular or Flex?
Just as I was ready to pull the trigger on a Wilson FGT-4, I was asked if I frequent underground garages a lot. The dealer told me that they don't stand up too well to getting smacked around by those height limit bars they put up at the entrances.
Unfortunately where I work, I have to park underground regularly. So he recommended a Wilson Flex instead. My concern is that I'm going to be mounting it on the spare so is the flex going to smack the roof everytime I hit a bump or is the regular fibreglass antenna rugged enough to to take a shot now and then in the garage?
I had a 8.5 foot fiberglass antenna bumper mounted on my YJ. I beat the hell out of it in every underground garage, as you can well imagine. It was cheap and I just didn't care - but it took all I threw at it.
On the other hand, I had a spring mount and I could fold it down and tuck it under my side mirror something like you see in military Hummers.
Thought about that as an advantage of the flex?
But did the spring mount bounce off the roof on a bad road? I don't want to end up scratching the hard top and tearing the soft top from the antenna.
....that's the only drawback for the flex I'm concerned about.
ive got a 4' firefly mounted on my rear plate with the cooltech kit, i tuck the tip in the Velcro lip of the rear soft top window.
ive been thinking about going to a whip and doing the mil tie down look
I was wondering that about my Flex, too. It certianly is "flexy" but I don't know if it could stand up to getting hit every 20 feet at 15mph while you climb to the 5th floor of a garage. Because it flexes so well, maybe you could use a bungy cord to tie it bent over to the side when you enter a garage. You'd have to improvise that a bit.
Anyone have an example of a quick release? I haven't found a suitable one yet.
I would just take the antena off, you don't need a quick release for that, is very easy.
P.S. Toad, it's becoming abundantly clear that you're some sort of freakin' modding genious!
