Rugged Ridge CB Mount Question (Over Rear-View)
How solid is the Rugged Ridge mount that attaches to the windshield loop? I ask because I'm getting ready to purchase either the Bearcat 880 or 980, and the 980 weights a pound more. If it is rock-solid, I'll go with the 980. If not, then I will go with the 880.
Thanks! |
Originally Posted by dmwil
(Post 4047671)
Thanks! I'd still like to know how solid the RR mount is, so please share your experience. Thanks! |
This section is not great for getting questions answered in a timely manner.
I just installed mine. I like it. It does make it so I have to use my rear view at a lower position but the whole look of the CB up there is really clean looking.
Originally Posted by cody0707
(Post 4047798)
I looked at the installation manual and it looks like it will be solid. I really like the mic cord holder at the top. Now I've got to check my antenna cord and see if I have enough extra length to take it up the A-pillar. I think I do, but if not, I'll have to go snag a longer one. I had a Cobra 75, but for the second time I had problems with the plug wires. Seems like they last about two years with tugging and such, and then need repair or replacement. I just got sick of it. I also felt I needed an external speaker, so I ordered a Cobra that looks pretty nice, but it is just too big to place anywhere functional. This overhead mount will be perfect, since the speaker will blast straight down, unblocked. I've seen a few reports that the 890 version of this CB has a really loud speaker, too. Can't wait to get it up and running! |
Don't know if the RR mount keeps the radio up a little higher or not but I made my own mount to put a buddy's Cobra 29 on. Think it cost me maybe $10. I'm slowly getting the balls to mount my new 980 in the dash.
Sent from my iPhone using JK-Forum |
1 Attachment(s)
I installed the 880 with the RR CB mount. I placed the cb bracket on top of the rr bracket and I didn't have to move my mirror down any. It does shake a little since you cannot center the radio bracket up on the rr mount. I made that mistake at first and then found out the driver's side sun visor wouldn't fit.
Attachment 594858 |
Originally Posted by erpeden
(Post 4048347)
Attachment 594858 |
(Post 4048347)
I installed the 880 with the RR CB mount. I placed the cb bracket on top of the rr bracket and I didn't have to move my mirror down any. It does shake a little since you cannot center the radio bracket up on the rr mount. I made that mistake at first and then found out the driver's side sun visor wouldn't fit. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=594858"/>
I was able to get mine to hold tight. I had to really crank on the bolt that holds the CB bracket. I used a nut drive on the bolt and a phillips on the screw and at my Wheates that morning. Then after I installed the CB I used a wide flat head to really crank down the knobs on the side. I couldn't get the tight enough with my hands. It doesn't move at all anymore. I do have to add a little bit of a rotation to get the cable to work since it was pretty stiff. Maybe 15 degrees towards the driver. It does sit parallel with the ground.
