What to do if my SWR won't adjust
I took off my firestik 4' and replaced it with a 3' so I can get in my garage. I had good readings witk the 4' but with the 3' my readings are all over the place. I've tried adjUsting it with the top screw and it's erratic on all channels. I ohmed my cable and it is good, I know I have a good ground. What else can I try?
Try adjusting the SWR at the antenna instead of the radio?
Also check to make sure your coax end is not damaged.
Check for corrosion around the base of the antenna.
R/
Will
R/
Will
Ah, gotcha.
Well as others have said, it would be good to check and inspect the existing connections (coax and grounds). It's easy to have a coax connector come a bit loose which could alter the SWR.
Then, if you still have that 4' antenna, re-install it and see if you still get good SWR (or not).
If you get good SWR with the old 4' antenna, I'd find or borrow a short length of coax (e.g. 3' ) and a barrel adapter to connect the existing coax with the extra short piece. Then re-measure the SWR to see if the extra length makes any difference or not. If the SWR improves, replace the coax with a single 20 or 25' length. If it doesn't improve (and it were me) I'd return the antenna as "bad" and get a refund.
Edit to add: If your meter has a fwd vs. reflected power setting it would be good to know the values. Often this info is more informative than the SWR.
This is my first cb install so I'm learning. On my swr meter in the forward mode I key the mic and use the adjusting knob to "test" on the meter. Then I turn the switch to "forward" and the reading I get is power out I think. I was able to tinker with it and finally got 1.3 on ch 1, 1.8 on ch 19, and 1.5 on ch 40. I can live with that, it's just a little worse than with the 4'.
I may have just said it backwards but I watched a YouTube video that was using the same meter that I have and I tested it with those directions.
