2010 Wrangler will start but gauges blank, stuck in park, wipers won't turn off? - Page 2 - JK-Forum.com - The top destination for Jeep JK Wrangler news, rumors, and discussion
Go Back  JK-Forum.com - The top destination for Jeep JK Wrangler news, rumors, and discussion > Jeep JK Wrangler > JK Electrical, Lighting & Sound Systems
Reload this Page >
Old 02-10-2019, 06:46 PM
Default Problem solved!
Originally Posted by schietj512 View Post
I have the same Iproblem with my 2007 JK. I have a switch installed on the neg battery terminal to disconnect the battery for towing behind my motor home. If I just turn of the battery switch and turn it back on it resets something and works normal. As long as the Ignition switch is in the run position or accessories position every thing works fine. After about 3 to 5 mins in the off position I have to reset it with the battery switch. For a while too low or too high humidity was the problem but now it makes no difference what the humidity is inside the can. The ding with the key in the switch and the door open means it is ok. If the is no ding it has to be reset. The wipers run as soon as and as long as the key is in the run position, the guages, turn signals don't work and other weird things happen. Did anyone figure out what is causing this?
I have just found the fix for this problem and another related issue. A second problem started happening where the wipers would just come on and couldn't be turned off. The turn signals wouldn't work and the head lights wouldn't work. But, this problem would come and go without warning. Fix-Replace the Instrument Cluster corrects both problems. Dealer price $469, online direct from Mopar $306. Both sources have units with the same part number and same one year warranty. I would say don't purchase remaned or used. Removal and install on my 2007 was very easy. 7mm socket is the size, 6 screws to remove. Covers snap off and on. Took me 20 minutes or less. You will need to write down the odometer reading before removing the Cluster.
schietj512 is offline
Quick Reply: 2010 Wrangler will start but gauges blank, stuck in park, wipers won't turn off?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
