Just installed IPF headlight swap but....
Old 02-05-2012, 02:31 PM
nicojames's Avatar
Default Just installed IPF headlight swap but....
everything installed fine no problems, when I went to look at them at night up close they are fine, but from a distance the passenger side seems brighter then the drivers side. I measured from 25ft against a white fence and measure 3ft up and the aiming is pretty on.....any thoughts? thanks..
2008 Sahara JKU
Old 02-05-2012, 04:41 PM
Ryan0260's Avatar
You may just need to adjust them as they can appear brighter or dimmer depending on how you are looking at them. I have these lights and they are identical in output
Old 02-05-2012, 04:54 PM
nicojames's Avatar
when you say adjust, do you mean use the torx 15 and play with the aiming?
Old 02-05-2012, 07:05 PM
Ryan0260's Avatar
Yeah just look in the owners manual. Its very easy. One way to do it is to get close to a wall or garage door at night. You can get pretty close just eyeballing it
Old 02-06-2012, 03:48 AM
nicojames's Avatar
thanks ima try tonight
Quick Reply: Just installed IPF headlight swap but....
