2013 JK Battery Issue
Has anyone else ever heard of or dealt with their Jeep losing power while driving and it acts like it cuts out or falls on it's face due to a battery issue.... That is what the dealership is saying that is the problem... They have replaced the battery about three different times now and it doesn't do it for a while but then it does the exact same thing a while later.... Need to figure out this annoying issue.... I can't seem to believe that it is the battery causing this kind of issues, maybe I am wrong though.....
David
David
Sounds like a bad ground issue to me, but that's just my knee-jerk answer to most power cuts. I have a hard time believing battery because it SHOULD be self-sustaining enough to run without it once started up (for typical road useage at least).
Did you check to see if there is an error code?
KG6SLC aka Eugene
