2015 rubicon hard rock help
i have a 2015 rubicon hard rock 12k miles i bought new. every so often my traction control light will come on and so will my electronic sway bar disconnect. the stealer ship said that they would not give me a loaner and wouldn't fix anything under warranty unless they could replicate it. does anybody have any advice on how to get them to fix it or something? any help would be appreciated
thanks
also one time the speedo went to zero and then started working again when i was doing about 40mph
thanks
Former Vendor
Do you have anything electrical added to the Jeep? The reason why I ask is we had someone bring us a Rubi with similar problems and it was a loose batter connection.
The person had a winch installed and they put the power wires on the batter nut which is made to tighten the terminals. We swapped the location and it was perfect.
good to know about the loose battery i do have a winch going to my battery i'll have to check that.
there is another dealership little farther away but not unreasonable. i will have to give them a call at the very least
Same exact vehicle here with winch attached to battery etc. I had the dashboard christmas tree every now and then. Was driving me nuts. I honestly forget what it was exactly but I do believe it had to do with a loose battery cable.
