3.8 JK cut out and not starting
Hi Guys,
I have a 3.8 Wrangler SWB. while driving the car just cut out and now gives the following error codes. P2107, P2122, P2127, P0123, P0222, P2111 and the red lightning bolt is flashing. when you try and start the vehicle the starter gives a click then stops. We have tried plugging the pedal into another jeep and it works fine but in mine it says no signal. I have been told it could be the TIPM and it could be the PCM but we have no idea. Has anybody ever experienced this? Sometimes when the key is turned on there is a clicking noise coming from the fuse box if you turn the key off and on then is stops
