5 pin relay vs 4 pin relay
It doesn't matter. You will just have an extra pin not being used. Just make sure you put your output wire on terminal 87 if it is a normally open relay or 87a if it is a normally closed relay.
jrsavoie (11-23-2023)
So I could just cut the extra wire as short as possible & be perfectly fine?
