So I have an install video of how to install the rear view camera on the 430N. One of the most asked questions, is does the 730N hook up the same way using the PAC CHYRVD Cable as does the 430N ?
Originally Posted by Chadc880
(Post 4156058)
So I have an install video of how to install the rear view camera on the 430N. One of the most asked questions, is does the 730N hook up the same way ???
you installing it with what interface? Thank You |
(Post 4156058)
nstall in bumper using included hole saw. Run wiring through grommet under jack and connect power to reverse light wire in harness just inside right rear corner (no need to go all the way to the tail light housing). White/Gray = positive. Black = negative. Run video wire along existing harness on passenger side to dash and up to the radio. Plug harness into back of radio. Go to dealer and hand them these directions: PARK VIEW REAR BACK-UP CAMERA VEHICLE CONFIGURATION Vehicle VIN must be updated with the sales code of the added accessory in order to enable system functionality. Using the DealerCONNECT website and the StarSCAN diagonstic tool, complete the procedure below: 1. Log on to https://dealerconnect.chrysler.com 2. In the “Vehicle Option” screen under the “Global Claims System” category in the “Service” tab, enter the vehicle VIN and add the sales code XAC (Park View Rear Back-Up Camera) as a “Dealer Installed Option” and code XRV (Audio and Video Output). 3. Confirm that the new sales code has been successfully added to the VIN. With the StarSCAN diagnostic tool connected to both the internet (via Ethernet port or wireless connection) and the vehicle, follow the steps below: 4. Using the StarScan select the VEHICLE PREPARATION and then select RESTORE VEHICLE CONFIGURATION. 5. Follow the step by step instructions on the StarSCAN to complete the Park View Rear Back-Up Camera vehicle configuration. 6. When the Park View Rear Back-Up Camera Vehicle Configuration is complete, go to the Validation Process to verify that the vehicle has been updated. VALIDATION PROCESS From the “Initial Start Up” screen on the StarSCAN follow the steps below: 1. Using the StarSCAN follow the menu to ECU VIEW, select TIPMCGW CENTRAL GATEWAY, MORE OPTIONS, ECU DETAILS and then CONFIG INFO 2. Verify REAR CAMERA PRESET- - - -SET is present. Mine charged me 1/2 hr labor. Some are charging more. Hope this helps. Backup camera mount http://www.extremeterrain.com/raxiom...-jstmount.html |
The only thing is dealer programming is so expensive it doesn't make sense , for the same price you get or interface and you get 5 times amount of feature , with a dealer you will spend $150 and just camera inout activeted
With us you get $175 interface . You get the following 1. Camera input activated. 2. Camera in drive 3. Video in motion 4. Navigation in motion 5. Control in motion |
Originally Posted by navtool.com
(Post 4156459)
With us you get $175 interface . You get the following 1. Camera input activated. 2. Camera in drive 3. Video in motion 4. Navigation in motion 5. Control in motion my dealer did it for free. on average most dealers charge $50-$70, and a lot will do it for free if its in for other repairs.... |
Navtool please stay off my postings and thread. You are not welcome on my postings.
(Post 4157095)
Navtool please stay off my postings and thread. You are not welcome on my postings. ddc4e
RE:
Navtool has hijacked other audio video posts only advertising his products. Do you see LockPick trying to sell their products on other peoples posts ? No.
Navtools response to my original question is not the factory option on how to install the rearview camera using factory items. Its a device or wiring that bypasses the factory setup. This use to be a Jeep Owner Message Forum. Heck, sales people from Jeep dealers were once kicked off of here. If I wanted commercial advertisement I would google it, or hear word of mouth. I thought that was against with Admins ?? :gak: |
(Post 4157240)
Navtools response to my original question is not the factory option on how to install the rearview camera using factory items. Its a device or wiring that bypasses the factory setup. This use to be a Jeep Owner Message Forum. Heck, sales people from Jeep dealers were once kicked off of here. If I wanted commercial advertisement I would google it, or hear word of mouth. I thought that was against with Admins ?? :gak: Sometime people don't know of all the options available out there |
