Adding stock sub enclosure to Jeep w/o one
A while ago I added a stock infinity sub enclosure to my jeep. I swapped out the sub for a JL and have it all wired up. Works great.
One issue I am still dealing with is how to go about mounting it securely. Since my jeep never originally came with the sub, I don't have the stubs that it usually would attach to. To those that have added the stock sub/enclosure to your non-equipped jeep, how did you go about mounting it? I have tried several different options and nothing really works the way I would like i to. |
to the top...
I'm in the same situation as you are. I too added a JL sub set up but haven't decided on how to mount it yet. I hope we can get someone to chime in on this. The one set up I have seen to to cut a board to lay all the way across the tub and mounts to the rollbars. It has the sub mounted in a downfiring position under the board. Not sure I like that idea though as it takes up a lot of storage space. It does get the sub up and out of the way though. The after market ones Iv'e seen like this on the Quadratech site have the sub one one side of the board, and the amp on the other.
Mount it in the same position as it would have come. Instead of using post studs just get self-tapping screws and a wide washer. Drill it into the tub. I guess it's not as convenient as finger-screw studs but it'll work. Molly bolts may also work.
I added a stock infinity subwoofer to my non-infinity jeep too and I used the cargo strap screw for the front subwoofer mounting point on the jeep.
For the 2 other mounting points I went to Ace hardware and picked up some nutserts. They were located in automotive section in the nuts and bolts bins. I used the predrilled hex holes in the jeep to install the nutserts. Here is what nutserts look like: https://www.jk-forum.com/forums/show...iedown-anchors |
Originally Posted by RUBIMAN07
(Post 1781875)
What JL did you go with?
Sent from my iPhone using Tapatalk It works perfect for what I was looking for. I had to make a spacer out of MDF in order for it to fit. I then dynamatted the entire inside of the enclosure and added a few strips to the back for good measure. |
