JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   Android 4.3 issues with Uconnect (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/android-4-3-issues-uconnect-293956/)
xsdbs Jan 8, 2014 06:48 AM
Moderators, please consider making this a sticky:
Android 4.3 issues with Uconnect and the following radios:
RES, REQ, RBZ and RHB
I have recently run into an issue with Samsung phones using the Android 4.3 SW. This issue is with new phones as well as phones that have been updated from the Android 4.2 and are on the CDMA networks (Sprint & Verizon). Phones that have been updated from the 4.2 version have been working well till the update was applied. It most likely will be on other CDMA networks as well.
*** I have tried the HTC ONE with 4.3 and it did not have the issue. ***
Here is what happens:
You attempt to place an outgoing call using Uconnect, the call will start the outgoing call and then you’ll hear “Call Completed” but the call is still active on the phone itself.
This is an issue with the phone and network which is currently being looked into by Samsung.
GotGecko Jan 8, 2014 07:10 AM
I have this as well. Same symptoms started on my Voyager headset around the same time.
xsdbs Jan 8, 2014 07:48 AM
Hmm, This is getting more and more interesting. I just spoke to another person with the 730N radio (which I don't have) who has the same issue since he recently updated his phone. Now you're saying that you have this issue on a BT headset, (correct?) May I ask which phone you have and the network that you're on? Thanks.
Twinkydog Jan 8, 2014 07:58 AM
I have a 730N and a Samsung Galaxy S4 running 4.3. Have not experienced this issue.
GotGecko Jan 8, 2014 05:46 PM
Verizon S4 at 4.3. And yes, same on the headset. Not very repeatable on either client but same symptoms. On the headset since I'm not driving, I can see that the bluetooth selection is not highlighted despite the headset indicating in call.
xsdbs Jan 9, 2014 10:32 AM
As I mentioned in the title:
Android 4.3 issues with the following radios:
REQ, RES, RBZ & RHB. The 730N is not one of these radios, so I would expect that you're not having this issue. I found the post from a person a different forum with the 730N to be interesting but I could not personally verify it because I don't have access to it.
xsdbs Jan 9, 2014 10:34 AM
Which radio do you have and where are you talking about not seeing the BT selection being highlighted?
GotGecko Jan 9, 2014 02:23 PM
RES and yes when this happens on the headset. Haven't been able to catch it in the Jeep.
xsdbs Jan 13, 2014 04:01 AM
excuse me for asking but I'm just not clear on this. You said that you haven't been able to catch it in the vehicle, are you saying that it does not happen over your Uconnect at all?
GotGecko Jan 13, 2014 06:08 PM
Happens. Not able to see if bluetooth is highlighted while driving.
© 2026 MH Sub I, LLC dba Internet Brands
