Android Based Head Unit Anyone?
On my other car forum lots of guys are going on and on about the Android based head units now available for cars like the Ca-Fi Dashlinq. Given that it supports true GPS navigation, USB input, OBDII readers (for Torque and similar apps), and can run pretty much anything right off the Android Play store I'm seriously considering one.
I'm about to order my 2015 Rubicon and was debating between going this route or going with the 430N. For the price this seems a vastly superior option. The only thing I seem to get with the 430N other than the warranty is true satellite radio vs streaming. I don't know that it's enough to justify the cost difference. Thoughts? |
Have you checked out tablets like the Nexus 7? Running pure, unalduterated Android, there is no vendor trying to lock you into their ecosphere. Though out of production, you can find 32-GB models for $130-150. Not my best production, but this will give you some idea of its utility ...
Nexus 7 Install in Jeep Wrangler JK Unlimited, Se…: http://youtu.be/k6UolIlksZs |
I've seen that done on the FRS/BRZ forum I frequent including one guy who fabbed up his own double dinn mounting bracket and recessed a head unit behind it he used as an amp.
To my understanding the CA-FI unit doesn't lock you into a specific set of apps like the Pioneer App Radio or the Parrot Asteroid. Instead you can use any app available from the app store. I liked the "finished" look of the CA-FI unit being in the dash and having hardware buttons. My major concern was the loss of the steering wheel controls. |
(Post 4022295)
Nexus 7 Install in Jeep Wrangler JK Unlimited, Se…: http://youtu.be/k6UolIlksZs 1. In the dash 2. Removable
Originally Posted by Skippman
(Post 4022302)
I was looking specifically at something like the Pumpkin Android Based Head Unit. It's 6.2" capacitive touch, has hardware GPS, a dual core proc, runs true Android and can be flashed to 4.4. It's also a standard dual dinn size which should fit with the appropriate trim kit.
http://ecx.images-amazon.com/images/...L._SL1500_.jpg |
I haven't looked at stereos in a while but when I put in an aftermarket unit in my truck a few years ago I was able to get an added module to keep my steering wheel controls working. I remember it being a fairly trivial cost as well. I had also looked at android units and found them to be lacking at the time. Its been a few years though and these new ones seem to be a lot better in that they are natively running android, not just some android apps. I have used the Nexus 7 in my JK for navigation and while it has worked I would much prefer to use something built in. With that Pumpkin unit, it says it has built in GPS, I wonder how it would handle Backcountry Navigator and if the GPS signal was strong enough to record a good track.
(Post 4022575)
http://ecx.images-amazon.com/images/...L._SL1500_.jpg http://www.autopumpkin.com/2-din-uni...-free-mic.html |
(Post 4022575)
(Post 4022592)
That would be very nice. Of course, I don't have steering wheel controls. Definitely would want it easily removable for security and updating. Also, I use my Nexus 7 to carry permits, campsite reservations, useful .pdf files (Jeep and camera owners manuals, etc) and .jpg images of specialty maps, so the ability to remove it quickly and sit around with others sharing the info is a less obvious need.
I'm curious how reliable the steering wheel control adapter is. I've used two of those now, one on my old Mini and one on a Dodge Stratus R/T. Both were flaky but I have to imagine with the level of granular customizablity you have on this thing it could be fine tuned. My reasoning behind persuing this is having my MP3's handy, having several GPS apps to choose from, not having to be locked into NAVTEC's expensive map updates, topo maps, and the OBD II features of it. Toss on a digital copy of the Jeep service manual for good measure and you're looking good. Also, as a HAM I'm kind of interested in this Software Defined Radio tuner. http://ecx.images-amazon.com/images/...L._SL1500_.jpg My co-worker has one and says it's amazingly accurate. |
Not having a control interface from your stock wheel controls to the head unit is a deal beaker for me. also to use many of the features you will need to have it connected to WiFi or a mobile hotspot. I also looked at the 430 for my 2014 Rubi, but it was weak in many area for the price tag, I ended up going with Kenwood DNN770ND that has all the feature one would need in a good head unit, plus it has true Garmin navigation which is extremely good. This unit has many apps that are internet connected but again you need a mobile Hotspot. Steering Wheel integration is a breeze with a PAC SWI unit, it will also replace the CAN bus which is what you need for the bells and whistles to work with Stock. the other plus to the Kenwood is the OBD gauge cluster interface, you can display most of your car data on the head unit.
