Backup Camera Mounting
So, it seems everyone is running either the 1/4" round backup camera mounted in the rear bumper or the little 1" square guy on the spare tire rack.
I'm curious if anyone's install anything a little beefier than those two. I've been looking at a couple on AliExpress that have parking sensors built in with them. One even has a built in distance meter. I'd love to use that one but I'm not even sure if I'd have anywhere I could mount it.
I'm curious where you're all getting your mounting brackets or if you're fabbing them up yourselves.
I bought a piece of aluminum from home Depot cut it, bent it and screwed the camera to it. Painted it matte black and it's perfectly poking out my rim. I will post pictures tomorrow.
I mounted mine in the tire center hub with quick disconnects behind. It has the parking assist lines
Attachment 627105
Attachment 627105
Curious to see where everyone is exiting the body to run your b/u camera wires externally. Currently I have the wires tucked and running inside down the passenger side. My original thought was to place it in the rear bumper for a clean out of the way install.....
Thanks for any input / suggestions.
mounted mine here...spare comes off without having to mess with camera, wires or anything. I wanted mine a little higher and have I it wired to a toggle switch inside as well as the reverse circuit. I did this so i can flip it on manually and check the load on the trailer as i'm driving. It works great for me. used electrical elbow and painted it black...camera i used fit perfectly inside. Pretty crappy pics i know.
