JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   Backup camera not working (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/backup-camera-not-working-262758/)
Scotchen Feb 2, 2013 07:00 AM
My backup camera stopped working. It's hooked up to come on when I engage reverse. Can anyone give me some tips on what to check for?
areeves65 Feb 2, 2013 08:04 AM
It's wired into your reverse lights. Find the wiring and make sure it's still got a good connection.
notsoricer Feb 2, 2013 05:04 PM
did you have your head unit tell it to turn on with a positive or negative switch? what head unit do you have? what type of connection did you use? what type of camera did you use? is it night vision with LED? (if so, do the led's still light up?
Aideon Feb 7, 2013 08:35 PM
If you're using an aftermarket stereo, try turning on the reverse camera manually (most stereos will let you). If it works, your reverse wire is loose, or incorrect.
If not, check the power and ground on your camera. If you have a multimeter, meter the power wire with a chassis ground. You should get around 12.66v. If you don't, gently pull on the connection to verify it. If it is loose, re-do it with a military splice, tape and zip tie. Done!
© 2026 MH Sub I, LLC dba Internet Brands
