Daystar Lower Switch Panel illumination?
Is anyone using one of their switches for cutting power like the esp kill switch? If so, is there a way to wire up the switch so when it's in the on position (cutting power to a circuit) it illuminates the led in the switch?
Vern you out there?
Vern you out there?
It is possible but you would have to use relays. I have two switched there, for front and rear lockers, and I am sending a GRND to activate my lockers. One normally needs a +POS wire to get it to work but with relays you can reverse or send any different signal.
I gues you would have to send me more details exactly what needs to be where and I could help you out. It isnt too hard but some thinking, a relay, and beer is needed.
Shoot me an email with details
