lockpick & in motion lockouts
Old 10-29-2008, 03:47 AM
horwitzs's Avatar
Default lockpick & in motion lockouts
I installed Lockpick and my U-Connect and voice recognition works great, but my inputs and dvd are still disabled while in motion.
Is this one of the items I need to check in the engineering menu?
Thanks.
Old 10-29-2008, 04:15 AM
mdlott's Avatar
Each time that you power on the Jeep, you need to enable the lockpick to use the in-motion items. To do this, go to the main Nav menu screen and click the power/volume button twice (quickly). This will enable everything until you power your Jeep off.
Old 10-29-2008, 09:25 AM
Augie's Avatar
Yup! you must have version 1, version 2 does that automacally. Just push volume button 2x's!
Old 10-29-2008, 02:56 PM
horwitzs's Avatar
No, mine is version 2, I just got it.
I tried it this afternoon and it didn't work... I'll keep monkeying with it for a while to see if maybe I am just not doing it quite right.
Old 10-29-2008, 03:57 PM
Augie's Avatar
call coastal, they have cs.
Old 11-02-2008, 11:45 PM
Mo-mud's Avatar
Make sure your not on FM when you x2 click..go to Sat or your hard drive. when on FM, double clicking goes to the rear camera for input.
Old 11-02-2008, 11:56 PM
Augie's Avatar
Check the dip sweitches on the lockpick box. Some have to be switrched for your needs. If you dont have the instructions let me know i can send them to you.
Old 11-04-2008, 04:14 AM
REL1203's Avatar
I just installed my new lockpick (V2) and I have to double click the power button twice as well to get the "Show Video" button to show up
Old 11-04-2008, 09:44 AM
bluer101's Avatar
I just installed the V2 two weeks ago in my Chrysler 300 and have no issues. Maybe it's because of manual trans? Something only with the Wrangler?
Old 11-05-2008, 03:28 AM
horwitzs's Avatar
I've gotten it to work now...
I'm not positive, but I think I activated it by holding the Uconnect button for 7 seconds while in DVD mode, which the manual says should only be needed if your DVD playback was completely deactivated by the factory, which mine wasn't.
Now everything works as it should, thanks for the suggestions everybody!
Quick Reply: lockpick & in motion lockouts
