Dash Speaker removal
Old Mar 28, 2008 | 04:02 AM
LDO-JK's Avatar
Default Dash Speaker removal
Am going to try and replace the dash and roll bar speakers this weekend. The roll bars are "no brainers" but the dash looks much more complicated. Is there an easy way to get at them or do you just have to contort yourself under the dash to get at them? Any help would be greatly appreciated.
Never mind...found it
Old Mar 28, 2008 | 07:22 AM
artpics's Avatar
This may be a waste if you have the infinity premium system with the Amp as the rear channels are limited (no high end) i changed my rollbar speakers with polks nice midrange and bass but no high end so i am going to install an amp soon to run direct.
Also if changing the fronts you will still get no high end due to the crossovers.
Also do a search someone wrote a good write up on changing the front location.
Old Mar 28, 2008 | 07:45 AM
wayland1985's Avatar
https://www.jk-forum.com/forums/show...hlight=removal
That should do it
