Daystar Lower Dash Panel Clips - help!
I got my Daystar lower dash panel all wired and switched up but I can't get the damn thing to clip back in. I can push it flush, but the stock clips just will not clip in. I've tried bending them differently, I've tried wrapping them in electrical tape...nothing.
I don't want a permanent or damaging solution like screwing it in so all the people out there with daystar lower panels -- what did you do?!
I've tried bending the full tab up and also tried bending up the middle catch of the orange clips with no luck
Hahaha....you think that they woulda made em better. My fix was this. I dabbed a small amount of superglue on the fattest part of the clip. Smashed the panel into place and pushed hard and held for about a minute. It held fine. I later yanked it out a few months later to swap out a switch and it broke the superglue bond without damaging anything. I repeated the process after making the change. Worked like a charm. I tried everything before trying this method. Hope that helps.
I messed with mine all the time and could get it to stay for several hours at a time but after months of fixing it every day I finally put two small screws in it and never looked back. I know this is not what you want to hear but it worked.
Thanks for the replies everyone. I'm gonna try some metal clips from the older JKs and when I discover that those don't fit I'll try the glue route. Had considered hot glue before but superglue is an option too. Screws if those don't work!
Kat
Kat
Hot glue tried but I don't think it was a match for North Carolina humidity. Super glue for the win! It's holding when I want it to and will still let me pull it out when I'm set up for the lights for the last 2 switches.
