Do I need a 2nd battery?
Old Feb 7, 2013 | 04:17 PM
mattyk's Avatar
Veteran: Navy
Default Do I need a 2nd battery?
Just got my 50" led bar in and also have a sub and amp coming in a few days. The sub will be powered constantly and the led bar will be switch fed and not used nearly as much. Think a 2nd battery is in order or do you think I could get away with powering everything off of one?
Old Feb 7, 2013 | 04:30 PM
Patman's Avatar
No.
I run two amps off my battery just fine. Your LED light bar will draw very little juice, and at this point a second battery wouldn't do you much good.
Old Feb 7, 2013 | 04:53 PM
JKphotoshoot's Avatar
I would do a bigger alternator before I would add another battery. Mine can barely keep the battery charged when the bass is pumping with the lights on at night.
Old Feb 7, 2013 | 06:55 PM
Freewill's Avatar
You are probably fine with one battery until you add more power-hungry toys.
When/if its time for more power, a second battery gives you more power when parked or when you need more power than your alternator can deliver while running (mainly when winching). A bigger alternator provides more power while the Jeep is running. Which one works best depends on how you use the Jeep.
Old Feb 8, 2013 | 06:24 AM
Ryan0260's Avatar
A single deep cycle battery should do the job
